Sponsored by:
Sponsored by: CARiD
A/C Recharge
Old May 25, 2021 | 05:26 AM
Prefondan's Avatar
A/C Recharge
I have an Evo X and I was wondering how to recharge the A/C system? How many oz does the system take? Will AC Pro do the job right? Thanks.
Old May 25, 2021 | 06:15 AM
splattj's Avatar
Our cars came with HFC134a (R134a)
16.0-18.3 oz is the factory fill spec on refrigerant.
It's a pretty standard system so anyone that can service AC should have no trouble with your car.
Old May 25, 2021 | 06:16 AM
Biggiesacks's Avatar
Did you discharge it, or is there a leak? If it's leaking you must fix that first. You need to replace any of the oil you lose dismantling the system to do the repair. Then you need to pull a vacuum on the whole system. If all the leaks are fixed it should hold that vacuum, you should wait at least 30 minutes to be satisfied it is holding the vacuum. Once you are sure the system is holding vacuum you can go ahead and recharge. I needed 2 12 oz cans to do the job on my evo 8, but I had left over in the second can. I'm not exactly sure what the capacity is on a X so you should probably look that up.
Old May 25, 2021 | 06:50 AM
Prefondan's Avatar
thanks! What oil would that take and what would the leak look like if it refrigerant or oil?
Old May 25, 2021 | 08:11 AM
splattj's Avatar
PAG 46 oil. Unless someone added dye, you won't see refrigerant leaks. Oil leaks look like oil. The refrigerant is much smaller molecularly than the oil so it can leak out without any oil leaks.
Old May 25, 2021 | 09:05 AM
Prefondan's Avatar
that’s some good information. Where would the oil need to be put in if needed? The AC compressor?
Old May 25, 2021 | 09:59 AM
Kevin.'s Avatar
What parts of the A/C system have been removed? On the 8/9 there's an equation in the service manual to figuring out how much oil is needed.
Old May 25, 2021 | 10:52 AM
Prefondan's Avatar
Mira fully intact, everything is still on the car as I haven’t taken it apart. The blower fan is still fine as well. This is what I picked up from AutoZone
Old May 25, 2021 | 01:19 PM
Kevin.'s Avatar
Does the compressor kick on? Is the clutch working properly?
Old May 25, 2021 | 05:31 PM
Prefondan's Avatar
The clutch doesn’t look like it’s spinning when the AC is turned on.
Old May 26, 2021 | 07:11 AM
splattj's Avatar
Does that recharge kit have dye? I've never had success with stop-leak on AC. It might work for a couple months with a small leak but if you blew out a seal or an o-ring it might not even hold the charge.
If you want to try out the parts store kit, go for it. If it fails again / doesn't stop the leak you need to take it to an AC shop to fix the leak, pull a vacuum, and put the right amount of oil and refrigerant in.
Old May 26, 2021 | 10:15 AM
Prefondan's Avatar
thank you! I’m sure that will probably be the way to go as any job done is never the easy way or the cheapest. I’m gonna put the recharge in and see what happens. Hope it creates enough pressure to engage the compressor. Big fingers crossed! I’ll let y’all know here soon!
Ruthless.
Aug 15, 2011 11:34 AM
Onkar02
Lancer Troubleshooting
Mar 26, 2010 04:49 PM
honki24
For Sale - Part Outs
47
Jan 2, 2010 09:35 AM
