Sponsored by:
Sponsored by: CARiD
Fuel Pressure Regulator?
Old Sep 14, 2023 | 02:02 PM
hairbear21's Avatar
I have a 2010 Ralliart with an Evo turbo swap and multiple other mods. The other day, I did a pull and the FPR hose popped off which caused a backfire and plug #2 to bust the insulator (the engine is okay).
I want to replace it with a better setup, however, I would like to find something that can go in the stock location without the need to plumb new fuel lines. Does such a setup exist?
Old Sep 15, 2023 | 09:47 PM
Jaraxle's Avatar
You can do an external FPR as shown here:
https://www.evolutionm.net/forums/pr...l#post11969735
You can skip the optional fuel pressure gauge (the top guy connected to the port).
On the right where it goes back to the tank you could use a barb fitting with a worm gear clamp to connect to OEM hose.
You will need to connect a mechanical fuel pressure gauge to the port I have the electronic gauge connected to in order to set the base fuel pressure (43psi).
Cruzamr
Dec 9, 2021 12:43 PM
Brian0206
Lancer Troubleshooting
Jul 18, 2009 06:06 PM
dEdiYT11
Oct 14, 2006 11:10 PM
Smogrunner
15
Jun 4, 2005 06:33 AM
NYEVO8
Oct 21, 2004 06:41 PM
