Sponsored by:
Sponsored by: CARiD
Pulled over ETS V3 Extreme help!
Old Sep 28, 2023 | 06:48 PM
goodfella999's Avatar
Pulled over for the 2nd time this month. Bought an evo x with ETS V3 exhaust and I believe a downpipe. How can I make it quieter? Do I need the V3 quiet system and sell this one? Should I avoid going back to stock because it can mess up the tune? Im new to Evo's and I think it sounds less loud than all the mustangs and camaros and they never seem to get pulled over.
Old Sep 29, 2023 | 01:34 PM
schuhie's Avatar
You should be able to find a reputable muffler shop to add in a small muffler or resonator to the current system without the hassle of selling what you have to get something new.
As for the tune, in "theory" an exhaust change like that could effect the tune. My suggestion would be to get a log as it sits and then again after to verify AFRs, knock, etc just to make sure everything is clean.
Old Oct 7, 2023 | 11:13 PM
Lightsaber's Avatar
I agree with schuhie. Try adding a Magnaflow performance muffler or an equivalent, and it should suffice.
If it's still too loud, then consider changing the catback system to HKS Super Turbo or ETS Quiet.
Also like schuhie said, do some data logging and re-tune as needed. Hopefully the tune is conservative and everything works out just fine.
Old Oct 9, 2023 | 01:35 PM
splattj's Avatar
Vibrant makes high quality stainless mufflers and resonators in all shapes and sizes so if you can figure out what you need. As long as you don't put anything in front of the cat, you shouldn't need a re-tune unless you introduce a huge restriction.
You could add dual canister mufflers in the rear section like the ETS Dual Muffler or you can try out a standard mini-muffler in the test pipe section with or without an HFC like the Ultimate Racing pipe. A resonator might help with drone/rasp but not much with dB levels.
Old Oct 13, 2023 | 09:06 AM
I wound up going with invidia q300 with muffler and resonator and im selling the ets. Thanks, much quieter now
nglett
Nov 30, 2019 10:57 PM
asu11
Jul 30, 2011 01:44 AM
airborne703
Apr 22, 2011 11:49 AM
Zydas
31
Nov 6, 2010 10:03 PM
ineedparts
ExtremeTurboSystems.com – WA
Jul 11, 2008 08:14 AM
