Anybody have the ECU Pinout yet
Nice of you guys to let us know you have it.... Don't share or anything.
http://roadraceengineering.com/evox/...-ecuwiring.htm
I'm hooking up a TurboXS Knocklite today and can't find the RPM pinout listed on the RRE website. I'll keep searching but if anyone can chime in it would save me some trial and error! Some of the pinout numbers are missing from their chart so I guess those are the ones I would check first. I know it outputs it somehow since my OBD2 scanner says I am idling at 700 RPM.
Update: Chances are I will try pinout #4 which is "No. 1 Ignition Coil (Ignition Power Transistor)" since as long as it sees a proper voltage range it will be able to set idle, half redline, and near redline knock settings for a TurboXS Knocklite I'm installing.
were u able to find the rpm signal man? i cant find it. also i was looking for the speed signal, i was told its the throttle actuator control motor relay (pin 84). But i'm yet to confirm. if you fund any of them please let me know. thanks heaps.
Guys I don't think this link is working...
Help please?
