Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
How To Use Factory 2 Step
Old Jun 17, 2008 | 03:51 PM
DrasticK's Avatar
Originally Posted by Gexxer
Just go out and do it yourself.... push the clutch in at a full stop and put the throttle to the floor. it stop at 5600 rpm and sit the for ten seconds max. after that the ecu stops the two step and begins drpoping the rpms.... they will go down very slowly as the computer is dealing with all that unburnt fuel you spewed
So when you rev your car, and the rev's dont go down as fast as they seem they should, this is normal? I've had it happen a few times to me, i don't like it.
Old Jun 17, 2008 | 04:00 PM
BluesunsXIV's Avatar
I love the 2 step but im always hesitant to use it, the stock clutch sucks *****, but ima use it up before i upgrade it. Anyone elses smells up the road for like 5 blocks? lol
Old Jun 17, 2008 | 05:09 PM
SpeedI2acerX's Avatar
Originally Posted by compscibOi
omg this is so simple, how hard is it to understand? It's been explained at least 3 times on here.... people just go do it yes its STOCK
so what your saying is that if you hold the rev at 5k, drop the clutch and miracle happens?
j/k
i tried it today. didnt let go of the clutch just rev it and wow it hangs there for quiet some time. the burnt clutch smell is normal right? even though i didnt let go of the clutch?
Old Jun 17, 2008 | 06:39 PM
yea guessing it is, mine smells BAD
Old Jun 17, 2008 | 07:24 PM
Riz5's Avatar
Yea I do. But I launch it a lil differently. I take the slowly take the foot off the clutch until it is about to engage. I leave the clutch there and then I rev it to 5000-5500 RPM for a few seconds and let it go.
Old Jun 17, 2008 | 07:42 PM
whats the difference between this and a regular launch?
Old Jun 17, 2008 | 08:28 PM
To me that would seem like more unneccessary wear becuase your keeping it at the catch up where the synchros mesh where as if you keep it all the way in u do engage the clutch until right b4 u drop it. Or am i the one *** backwards? lol any comments ppl?
Old Jun 17, 2008 | 08:29 PM
at the catch point* do not engage*
Old Jun 17, 2008 | 10:16 PM
Gexxer's Avatar
This car is a drive by wire ----- electronic. That means the ECU control the revs and just lets you ask it to give you more. when your revs stay high it means the ecu is detecting too much fuel in the exhaust and its trying to burn off excess to get the emissions back down.... i think.... someone tell me i'm retarded and explain it the right way
Old Jun 18, 2008 | 11:41 AM
tunermt's Avatar
ecu looks at VSS, and clutch switch. If you are not moving and the clutch is in the ecu will cut ignition (if its a 2 step) (or possibly retard if it is a true anti lag, I doubt they would do this from the factory though) I would guess the ecu only lets you use the "launch control" for no more than 10sec because it shouldn't take that long to decide if you are going to launch your car or not and Mitsubishi doesn't want you sitting there bouncing off a revlimiter at 5k all day. (not to good for warranty)
Old Jun 25, 2008 | 02:04 AM
ODUB's Avatar
it was the same way on the IX's...it's not rocket science....
step 1: stop
step 2: push in the clutch
step 3: put the car in 1st
step 4: floor it, and keep it floored
step 5: let out the clutch till you feel it grab, then let go
step 6: get ready to shift to 2nd because if you did the first 5 steps right, you should be hauling ***...oh wait, you're in a X...forget that last part about hauling ***. that's for IX owners
Old Jun 26, 2008 | 04:26 PM
tunermt's Avatar
hahaha step by step
that should be pretty straight forward for everyone.
Old Jun 27, 2008 | 12:37 AM
tim85851's Avatar
step 1: stop
LOL @ step 6!!!
Old Jun 29, 2008 | 03:05 PM
ggevoIX's Avatar
what if i'm already it first before i stop?? do i have to stop then take it outta 1 and then put it back in 1st???
hahaha j/k!
Old Jun 29, 2008 | 09:09 PM
ibarkovic's Avatar
step 1: stop
thats just dumm , the 6th part
