Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
How To Use Factory 2 Step
Old Jul 1, 2008 | 09:36 PM
  #31
whyb2nd's Avatar
right on thanks, launches like a raped ape. be careful with clutch engagement, slow but consistant until it bites.
Old Apr 8, 2009 | 06:08 PM
  #32
Farred's Avatar
Originally Posted by STi2EvoX
Just push the clutch in while stopped, put the car in first gear, stomp the gas, wait for it to bounce off 5 or 5.5k (it's one of the two) and after a couple seconds it builds a little bit of boost. Let the clutch out and you're off. When you let the clutch out do it quickly but not too fast. Don't side step your foot and "pop" the clutch out, that produces driveline shock that's not good for your transmission, Let it out too slowly and you'll fry the clutch, and with the stock clutches in these cars being soft and underrated they can barely hold the power that the car is making stock for rolling starts let alone a hard launch. All it takes is one and your crappy mitsu clutch goes bye bye, I hope this helps...
i tried this today and popped a p1238 code. I was completly stopped and pushed the clutch all the way in and stomped on the gas. It went to 5500ish and then threw the code and the car all but died. wth? would it matter if i had an accessport tune?
Old Apr 8, 2009 | 06:22 PM
  #33
Evo a Mula's Avatar
Originally Posted by ODUB
it was the same way on the IX's...it's not rocket science....
step 1: stop
step 2: push in the clutch
step 3: put the car in 1st
step 4: floor it, and keep it floored
step 5: let out the clutch till you feel it grab, then let go
step 6: get ready to shift to 2nd because if you did the first 5 steps right, you should be hauling ***...oh wait, you're in a X...forget that last part about hauling ***. that's for IX owners
loool thats the same thing my buddy with a red 9 said until he lost its ok i still love 9s
Old Apr 8, 2009 | 06:26 PM
  #34
Evo a Mula's Avatar
how exactly do you know when it bites
Old Apr 8, 2009 | 07:43 PM
  #35
CatalystGod's Avatar
You're gonna see the revs go down a little bit. Its basically when you are slipping the clutch. Do it for too long and you end up with the lousy smell. Do it for too short and you get bogged down. The clutch release needs to be just right. Remember, all this needs to happen in less than 2 to 3 seconds.
Old Apr 8, 2009 | 07:44 PM
  #36
Clipse3GT's Avatar
Old Apr 9, 2009 | 07:53 AM
  #37
jmorris1027's Avatar
If you have to ask these questions over and over, you shouldn't be launching your car.
Old Apr 9, 2009 | 08:06 AM
  #38
Farred's Avatar
bump
Old Apr 9, 2009 | 05:12 PM
  #39
Excalibur's Avatar
bump
That's not normal. I have the exact same setup as you and I had no problem with mine.
Old Apr 9, 2009 | 08:57 PM
  #40
REDEVO08's Avatar
step 1: stop
Thats pretty funny till he gets a tune..ahaha
Old Apr 9, 2009 | 09:32 PM
  #41
aftershock141's Avatar
step 1: stop
Funny thing is your car is slower than a lot of the modified X's. So you're faster than the stock ones. Oh boy.
Old Apr 13, 2009 | 04:13 PM
  #42
atombomb33's Avatar
EvoM Community Team
I can smell burnt clutches and destroyed transfer cases after reading some of the posts in this thread...
Old Apr 13, 2009 | 05:34 PM
  #43
lowkey's Avatar
Registered User
For all you smelling burn clutch material... that's $200 you smell.
Smell that 5 times or so and that is your clutch.
Old Apr 13, 2009 | 07:03 PM
  #44
Excalibur's Avatar
****! I only have around 3 left. What is a good aftermarket clutch? I want something that doesn't make extra noise or any other drawbacks.
Is there a company that upgrades the oem transfer case?
Old Apr 14, 2009 | 04:14 AM
  #45
MarkM's Avatar
twin plates make noise when the clutch pedal is depressed, but you can't hear it inside the car, do it properly and have peace of mind when you mod, my Cusco Twin is excellent, only slightly heavier than stock, very easy to drive, and feels awesome
