Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
emblem removal and reinstallation??
Old May 27, 2008 | 04:39 PM
Amanda725GT's Avatar
does anyone have any ideas on how to remove the emblem and then put it back on
Old May 27, 2008 | 04:55 PM
ilive2win's Avatar
to take the emblems off i used goo gone and fishing wire and to put them back on im guessing something like 3m 2 sided tape
Old May 27, 2008 | 04:57 PM
kanyonkid's Avatar
i let mine cook in the sun and carefully peeled it off with a flat object.... then used same sticky stuff to put back on
Old May 27, 2008 | 04:58 PM
_Chris_'s Avatar
Use a heat gun or blow dryer first to loosen the adhesive tape.
Old May 27, 2008 | 05:59 PM
zer0dds's Avatar
Like everyone else said, I just used my gf's blow dryer and some fishing wire (I heard floss works well, too). Heated it up for a bit first, then carefully stuck the wire between the back of the emblem and the car and just worked it from one end of the emblem to the other. Use some goo gone to get rid of the excess glue. On my old car, I had to clay it once to get rid of all the minuscule stuff that was left.
Old May 27, 2008 | 11:51 PM
is300's Avatar
+1
Old May 27, 2008 | 11:59 PM
xXBadAndyXx's Avatar
if your adhesive has dry rotted i would use the eraser wheels that attach to battery drills it works really well and leaves both the emblem and the paint very clean. and if you all ready have the drill it is like a 3 dollar drill bit piece not bad and really fast.
Old May 28, 2008 | 08:35 AM
Taryon's Avatar
For taking the emblems off, you can use any hair-dryer to warm up the glue - just be sure not to get too close to avoid any possible damage to the paint. If you want to play it safe, an easier method (and this is what I did).. let the car sit in the sun for about an hour or so instead.
Once the glue is softened and warmed up, fishing line works the best as it usually won't break on you but household floss works just as well. Just be prepared for it to break every once in a while, in which case you'd just take another line and go at it again.
Once the emblem is off, just rub some Goo Gone on the surface and wipe away.
Old May 28, 2008 | 02:14 PM
UFO's Avatar
UFO
Putting the emblem back is a problem. You are guaranteed to f up the adhesive one way or another. So, buy some 3M double sided foam tape, scissors, and an exacto knife. You'll have to trim the 3M tape to fit the emblem and that's a ***** of a job.
Old Jun 4, 2008 | 09:01 AM
STi2EvoX's Avatar
If it's a new car then the adhesive is still fresh and hasn't really taken to the paint. I pulled mine off with my bare fingers and almost all the adhesive came off with it. The remainder I just rubbed my finger over and it balled up and came right off. Then a wet cloth to wipe off the dust left behind the lettering and voila. Done.
Old Jun 4, 2008 | 09:07 AM
alloutDSM's Avatar
why do you want to take it off and then put it back on??? just for kicks?
Old Jun 4, 2008 | 12:05 PM
Taryon's Avatar
She might be relocating an emblem.
Old Jun 4, 2008 | 12:09 PM
bluebyu36's Avatar
to paint it proably
Old Jun 9, 2008 | 08:08 AM
BestOFbothWrlds's Avatar
yeah shes painting it lol
Old Jun 11, 2008 | 06:30 PM
Mzderrick04's Avatar
I used my finger nails to peel mine off and then goo gone to remove the adhesive....
