Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
sidemarker help
Old Aug 18, 2008 | 09:28 PM
trickytrick's Avatar
sidemarker help
does anyone know how to keep the sidemarkers on when the full headlights are on?
Old Aug 20, 2008 | 06:19 AM
Aseller's Avatar
What sidemarkers, the ones in the corner of the headlight?
Old Aug 20, 2008 | 08:35 AM
NO_WAY's Avatar
your blinkers?
Old Aug 20, 2008 | 09:05 AM
the ones on the fenders
Old Aug 20, 2008 | 10:48 AM
SilverEvoX's Avatar
I don't think you can keep the fender side marker lights on without having the full headlights on because the parking lights don't keep the side markers lit I don't believe.
Old Aug 20, 2008 | 09:18 PM
im pretty sure we can but we need to splice a certain wire
Old Aug 20, 2008 | 09:27 PM
ThunderOZ's Avatar
You should just be able to splice into the parking light power wire and connect it to the fender light power...
Old Aug 20, 2008 | 10:10 PM
do you know if i signal they would be on at the same time with the front signal or alternating?
Old Aug 21, 2008 | 07:32 AM
Aseller's Avatar
Why do you want to have those on? Just curious...
Old Aug 21, 2008 | 08:19 AM
Slimdatwelve209's Avatar
jdm look??
Old Aug 21, 2008 | 09:48 AM
yea and i think it looks better. im lookin for amber sidemarkers too
Old Sep 20, 2008 | 06:20 PM
toolapcfan's Avatar
You can wire them so they are on all the time like parking lights and then blink when you use your turn signals. You wire them to have a floating ground and you'll have to tap into wiring for the parking lights to accomplish this. You cut the ground wires for the sidemarkers, or better yet, extract the wire terminal from the bulb harness like a professional would. Remove the wire from the metal terminal that you pulled out of the harness and solder a new piece of wire to it. I would use the same gauge wire as they used OEM. Run this wire to the parking light wiring. Try to do so inside the car since hacking into wiring outside where water can get at it is a bad idea, unless you're going to put adhesive lined heat shrink over the splice you're making. Anyway, either use a wire tap to attach this wire to the parking light positive wire, or, like a professional, remove the wire's terminal from the harness and solder your new wires onto the terminal, but first, make sure that you can still insert the terminal back into the harness with all three wires connected to it. There's a pretty good chance you won't be able to solder on your new wires. So you'll have to do the next best thing and just tap the parking light positive further away from the harness. Here's a link you can check out for a visual representation as well as instructions. This shows how to wire parking lights to be turn signals, but the idea is the same, the wires are just transposed, we're tapping into the parking lights instead of the turn signals. http://www.danielsternlighting.com/t...rkerflash.html
How they blink will vary, depends if your parking lights are on or not. In one case they'll be out of phase with your turn signals and in the other case they'll be in sync.
Old Sep 21, 2008 | 10:28 AM
aftershock141's Avatar
Pm me where to get some when you find them.
Old Sep 21, 2008 | 12:29 PM
i think password jdm has them but i dunno if they r the same as the evo
Old Oct 18, 2012 | 05:25 PM
JDMEVOLEX's Avatar
I just got my amber lights in the mail from eBay. I was Planning On doing the same thing I'll try to post a write up tomorrow when I install them
