removing spoiler?
See this bro. This is a how 2 I did. Should be the same for the X I assume. This will get the GSR wing off, since I guess since I just read that the MR does not have tape
http://s3.zetaboards.com/2008_Lancer...7004349/1/#new
tried to get mine off the New RA and its freaking on there good!. Same Same 2 bolts on either side and the damn double sided tape that is stiiiiiiiiiicky. gonna try the heat gun cause I couldn't even get 2 mils of gap.
G'day to all... does anyone know and have step by step instructions on how to remove the evo x boot spoiler?... in particular the plastic section on the underside of the spoiler?.. I'm thinking of colour coding it, however I have no clue how to remove the plastic section... any and all help would be much appreciated.. Thanks in advance!
I went out and bought some medium weight fishing line and goo gone spray....spray the goo gone into the gaps around the bottom of the spoiler, while working the fishing line back and forth to lift up the tape. Takes a few minutes on each side, but nearly guarantees a clean removal once you're done.
Then goo gone the residue once it's off. My only question is a +1 to the plastic tabs, I don't want to pry them out. I used white vinyl from decaldriveway to cover the holes...it looks good for the time being and will hold me off until i get a WW painted Do-Luck trunk....
jmrussell89
Nov 6, 2024 06:01 PM
lancerlover07
04-06 Lancer Ralliart How To Requests / Questions / Tips
Aug 14, 2016 11:56 PM
Champion3
Oct 11, 2015 02:05 PM
afi1827
Aug 7, 2012 10:26 AM
