Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
How to remove rear seats?
Old Sep 23, 2010 | 12:16 PM
importerok's Avatar
I've read the 8&9's back seats are lighter than the 10.. but even still, weight is weight.
A good rough estimate to go by as far as weight reduction is as follows:
10lbs removed = +1hp = .01 seconds in time savings
Obviously not science, but it stands to reason that is fairly close. Or at least a good estimate to decide if it is "worth it". Now we just need to find out the weight of the seats...
Anyone know where to find a list of the weights of each part that is put into the Evo. A manufacturers list has got to be out there somewhere...
I typically don't drive more than one passenger, so I fully intend on removing mine. Plus if you do it while the interior is new, you can replace them when you go to sell, and the car looks amazing, or you can sell them independently in a few years, once everyone else's are all used and worn down.
I have a buddy who drives a stripped BMW E30, and every night before he goes to bed, he finds at least one thing he can remove from him car. Weight is weight!
Old Feb 8, 2012 | 06:01 PM
Tahoe55's Avatar
Originally Posted by evox119
Hey guys I got some pics that might help out with removing the seats. Pretty much just follow what the other posts say to do. Should take about 10 min for removal and reinstall
+1 for a great pic and post
Just wanted to add some key learnings.
For a smooth removal of the seat bottom and avoid bendng your rear seat, 1st locate the clip on each side by running your fingers along the bottom edge of the seat. 2nd, pull up using both hands stradling a clip. Do one at a time.
This will reduce any torque getting applied when using one hand. The clip will let go of the hoop with some force but doesn't require too much. There are a couple of posts on other forums regarding bending the seat by lifting with one hand that probably was caused by lifting from farther away from the clip than recommended.
Old Apr 30, 2012 | 10:54 PM
Jose A's Avatar
Nice Post I just got my EVO X iam gona strip the trunk and remove rear seat tonight so i can have that raw evo look plus it will help me out with auto x... Removing the back portion of my s2k was much more complicated than this lol
Old May 6, 2012 | 01:02 AM
korzunm's Avatar
When I take off my rear and front seats
It helps me to drive 0.4 seconds faster
Old Jan 2, 2013 | 01:41 AM
jlee747's Avatar
How does the seat come out after the three bolts are undone?
Old Jan 2, 2013 | 04:32 AM
beetle_orange's Avatar
Lift up and pull towards you
Old Jan 30, 2013 | 05:33 PM
seanr8368's Avatar
Why doesn't somebody just make a video?
Old Jan 30, 2013 | 06:12 PM
Snakes709's Avatar
probably because its one of the easiest things to do in the evo? lol
Old Jan 30, 2013 | 06:40 PM
seanr8368's Avatar
Lot of help thanks
Old Feb 7, 2013 | 03:16 PM
clayt006's Avatar
Really easy to do. Thanks!
Old Apr 24, 2013 | 10:16 AM
jwongx27's Avatar
subbed for the 3 bolts hahaha i will be doing this for ****s and giggles
Old May 23, 2013 | 09:22 AM
sprisneo's Avatar
weight reduction ftw
the seats were heavy as sh**
Old May 23, 2013 | 03:25 PM
skone's Avatar
rear seats aren't that heavy, but they're not that hard to remove!
Old Jun 16, 2013 | 10:04 PM
wrobbin's Avatar
You need some basic tools like T40 torx socket, T45 torx socket, Socket wrench... with the help of these tools you can remove rear seats.
1hotrod
17
Feb 6, 2017 01:51 PM
1hotrod
Feb 13, 2014 12:01 PM
FloopyDisk
Apr 18, 2011 11:51 PM
smoke90
May 24, 2010 03:38 AM
.MM
May 17, 2010 08:38 AM
