Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Prosport boost gauge install...help!!!
Old Jan 31, 2009 | 08:16 PM
fknchristoph's Avatar
I tried the orange wire to the green wire, and for some reason my boost gauge wont turn. As soon as i put the negative on the battery back on Its on.
And When i start my car, the boost gauge reads 15 inHg and then when i accelerate at WOT the gauge shoots to the max of 25psi and I'm a stock x with a tbe no mbc
What could be the problem?
thanks
Old Feb 3, 2009 | 07:37 AM
kingu's Avatar
thanks
check post #57 here https://www.evolutionm.net/forums/ev...an-hell-4.html
see if that helps
Old Feb 4, 2009 | 12:20 PM
What color wires did you have coming off your sensor and what color wires did you have coming off your gauge?
I had a black, green, red off my sensor and Black, red, white, orange off my guage.
I linked the white to green for information
black on the sensor was a ground
and red i didnt even tap into a fuse
for my gauge:
white went to the green,
black went into a ground on the floor
red tapped into my cig lighter
orange isnt used
Old Feb 5, 2009 | 09:50 AM
kingu's Avatar
for my gauge:
orange isnt used
Mine came with a harness with plugs on either end. Other than splicing "extensions" into the sensor wires I didn't have to do anything. One end plugged directly into the sensor and the other end plugged directly into the back of the gauge. I especially didn't have to connect any of the sensor wires directly to ground. This is the gauge I have http://prosportgauges.com/amber-whit...ost-gauge.aspx If you have a different one, the wiring may be different.
I know you're frustrated, like I was, so feed me some more info (maybe some pics too) and I'll try my best to help.
***edit: After looking closer at the above link and noticing the picture lower on the page that shows the hardware...
https://01f6bbb.netsolstores.com/ima.../peakboost.jpg
...my sensor looks nothing like that one. If that is the sensor you have then I probably can't help.
***edit again: my sender looks like this one...
http://images.google.com/imgres?imgu...3Doff%26sa%3DG
Old Feb 5, 2009 | 02:34 PM
Dave99gst's Avatar
Prosport does have a tech line you can call also.
Old Feb 5, 2009 | 07:00 PM
my guage looks like that one but in blue. I'll try and snap some pics later. only have a camera phone.
Old Feb 5, 2009 | 07:24 PM
boostin20's Avatar
To all of you who can't get the guage to turn, read the sheet- it explains exactly how to do it. If you follow that, you can't f it up. If you want it to switch between amber/ white or green/white whenever you want with headlights on or off, a 2-way toggle switch has to be wired in.
Old Aug 30, 2010 | 01:48 PM
TJs98GT's Avatar
so im having this same problem. i replaced the sender and it didnt go away. i tested my gauge in another car and it works fine. i checked my wiring 10 times over. and cant find a problem anyway. i know the ground is working fine because it shares a ground with my wideband. i have the same style as the original poster. the plug from the sender ends at another plug that goes right into the gauge.
what i dont understand is it worked fine for a good week or so and then hasnt worked right since. first it would do this once in a while and then work fine and then stop working and then work fine and then eventually just quit all together and keeps beeping and flashing continuously i just been driving around with it unplugged looking at a dark gauge. it pisses me off so much.
and i really want the prosport boost gauge because i think it matches best to the stock gauges in color and font and all.
Old Aug 30, 2010 | 01:58 PM
evolutionxtac's Avatar
Prosport needs to work on their wires and harnesses.
Old Oct 22, 2010 | 04:56 PM
dgrumpys's Avatar
^ whateverrrrrr
prosport is the shiznonit ! quality at a fair price
Old Oct 28, 2010 | 07:11 PM
alex3dworld's Avatar
i wrote about those a few month ago here, use the search tool.
you have your wiring wrong some how or your electronic sensor is bad, i got one bad becouse my first instalation, facing up the plug entrance , with the first rain ....bump short circuit///had to replace the sensor.
they are good in general have it for two years now, without a problem.
Old Oct 28, 2010 | 07:45 PM
wrxnevox's Avatar
what kind of gauge you got electrical or mechanical?
Old Mar 18, 2012 | 05:08 PM
wjamyers's Avatar
http://youtu.be/D4__UrvRKKk
any ideas?
Old Apr 4, 2012 | 12:58 PM
sensor is bad, send it back to your seller, i had a bad sensor doing exactly the same. boost to max and alarm on all the time, or buy a newone,
check your installation were you are conecting the cables to the sensor , it has to face down, to avoid rain drops, if any drop or water goes to the sensor plug it will damage the sensor. they didn't design too well that sensor
Old Jun 17, 2013 | 03:26 PM
StormTroperX's Avatar
My boost gauge stays on all the time unless I remove the ground... What can I do? I have the red connected to the door lock. I changed it up and connected it to another power source and the gauge was turning off and on with ignition but was reading incorrectly...
Any ideas?
