Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Tow Hook Install?
Old Apr 23, 2009 | 03:53 PM
morfhious3's Avatar
basically nobody has answered the question how to install the tow hook.usdm version dont have a hole, so you have to drill.then what?you weld it?put a bolt in to lock it?but the thread pitch on the tow hook is big.by the way i got the one for mini.so what can you doto it to be secure on the aluminum beam?
Old Aug 16, 2009 | 08:41 PM
pips's Avatar
Tow hook pics
Front T1R tow hook and rear Benen tow hook installed...
The installs were fairly simple. I made a custom bracket/clamp for the rear out of 3/8" 6061 which extended the tow hook out far enough to see it and for it to be functional.
For the front you need to remove the plastic cover on the left side of the bumper and then mark where you want to mount the tow hook.
Remove the front bumper.
Remove the plastic duct in the left side of the Aluminum bumper as well as the styrofoam piece.
Drill your hole
I used a wedge spacer I bought from Brafasco in order to straighten the bolt out. I placed it on the inside of the hole and it made it pretty straight with the use of just one wedge. The part of the bumper where you mount it is contoured so you need to do (something like) this or the tow hook would look too crooked coming out of the bumper.
I also used a couple more spacers on the mounting bolt to get the right length and make the tow hook more flush
Then replace your bumper and fasten with a couple bolts...line up where you need to drill out the plastic cover - or you can just leave it off if you're lazy- but I prefer to make it look nice and neat. I had to dremel mine out a bit after drilling but it's a perfect fit now.
And that's pretty much it. I hope this helps!
Attached Thumbnails Tow Hook Install?-dsc03805.jpg   Tow Hook Install?-dsc03850.jpg
Old Aug 16, 2009 | 09:23 PM
tephra's Avatar
i dont understand, my X GSR has a hole behind the square plastic bit on the bumper..
there is even a towhook in the boot you just screw in..???
Old Aug 17, 2009 | 08:27 PM
stokEd's Avatar
The USDM bumpers are different; they're about twice as thick as the JDM (and AUDM it seems ) crash beams and don't come with the threaded bung for attaching the hook (for no good reason.)
Old Aug 21, 2009 | 08:50 PM
pips's Avatar
Perfect, do it up. Use that hole to mount it....
Old Aug 27, 2011 | 12:21 PM
pips's Avatar
tow hooks available here...
Evo X and ralliart front and rear tow hooks...
http://toronto.kijiji.ca/c-cars-vehi...AdIdZ307238268
Old Aug 29, 2011 | 11:24 AM
deludedbuzz's Avatar
Man I wish there was a good easy solution for a functional front tow hook install.
Old Aug 29, 2011 | 05:27 PM
pips's Avatar
Front tow hooks
I'm making some of those front hooks up this week. I'll post some images of it installed!
Should be fairly simple to bolt on but I'll update on that
Old Dec 5, 2011 | 05:54 PM
lil ayzian's Avatar
requires some drilling
manolo2011
04-06 Lancer Ralliart How To Requests / Questions / Tips
11
Nov 4, 2019 05:47 PM
smurf34
Sep 7, 2013 11:03 AM
Brsox10288
Nov 10, 2010 01:36 PM
racerferrari
Mar 6, 2006 01:18 PM
