A-Pillar fabrication Pictures
btw OP the piller looks good, I would suggest running some bondo over the rest of the pillaras there is a clear transition that shows through the paint (that will soften the transition) and make the pillar much better. its a great first effort though.
That example, plus when I ran the line for my Escort, debunked those myths. I am quite confident that if my airbag ever deploys it will be the sudden stop that kills me not the a-pillar or any of the gauges I have on it.
Burned out on sanding this weekend. Probably will do a test fit and if it just doesn't look just right, then I'm sanding. I have the black paint in the garage!
As rough as I was holding the pods and sides of the pillar, while endlessly sanding, its not coming off. As I stated before, not much flexing goes on in this area. But would like to see a step by step of the glass project. Might tackle a sub box using glass.
Carry your off-topic argument with Talon66 to PM. But I will answer your question. The a-pillars are teathered to the frame with a THICK plastic strap. If you have not took off the a-pillar, its anchored pretty good. A-pillar is not coming off. So if the gauges are properly seated, they will not fly anywhere.
