Ralliart Taillight Install w/pics
Perhaps this has been covered elsewhere, but instead of buying the RA tail-lights, why not black out the stock ones yourself? I mean, you just need to open the casing, plenty of masking tape and high temp black paint. Should be able to replicate the RA lights that way.
Ben
Ben
From: Philly, Germany, Japan, UK...South Dakota (Da Sticks).......
Good write up man. I wish I had something like this when I put my lights in back in November. I was so excited to put the lights in I had pulled the foam out without unscrewing it first......honestly I thought that it was just on pegs that kept the two pieces in place. Minimal damage for great looks and the pieces can still be secured (without movement) so it's all good.
When changing the outer lights you can just pull the connector out through the opening instead of removing the outer panels in the trunk. It worked for me...might be a little quicker.
The sub gets in the way when trying to get to the driver side tail. Made it not worth the effort to me so i just untwisted the 3 connectors and used the original bulbs and harness
