Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Quick Install: Nisei 1PC UICP with Front Bumper on
Old Apr 26, 2009 | 10:02 PM
supergengo's Avatar
Thanks for the write up!
Last edited by supergengo; Apr 29, 2009 at 12:02 AM. Reason: Misread the part about the snorkel.
Old Apr 27, 2009 | 05:24 PM
aftershock141's Avatar
His doesn't look really that far over.
Here's mine:
Old Apr 29, 2009 | 10:13 AM
wongck's Avatar
Just some more tips for readers:
1) Make sure you have a 12mm socket that's deep enough to tighten the T-clamps. I had to boost leak my way to Kragen to get a deeper socket because the stud was already hitting the my ratchet
2) Make sure the clamps are tight. Cannot emphasize this enough. If you think it's not tight enough, then it's not. If you think it might be too tight, then you're almost there. Factory clamps are creased when you pull them off so that should give you an idea of how tight it has to be.
3) watch out for razor-sharp heat shield. I did not cut myself, but many people have.
Old Apr 29, 2009 | 10:33 AM
Keepthechange's Avatar
where did you purchase your nisei UICP from ? i can't seem to find them
Old Apr 29, 2009 | 10:50 AM
wongck's Avatar
Contact Jed at Maxum Technologies. They tend to reply to their PM at random times. One week I couldn't get a hold of him, and another week he would reply within hours. I ordered my pipe on Sunday and I got it on Tuesday, so they're obviously doing their job.
Old Apr 29, 2009 | 04:58 PM
Excalibur's Avatar
So, I read through this, but should I use the couplers from the kit or the oem ones?
Old Apr 29, 2009 | 06:23 PM
Originally Posted by THEMEMPHISFORCE
It looks like you UIP is way to far to the right, too close to the airbox. Seems like it should be about an inch closer to the valve cover-cover. It looks really good anyway. I got one question with a one piece UIP won't it or the mounting become damaged over time from the engine torquing and rocking back and forth under acceleration? Isn't this why the factory one is made to flex? Just wondering, I could be way off base.....
This post got me wondering as well.... can a single piece UCIP damage something ? Im ready to order one asap...just wondering to go with a single piece or a two piece
Old Apr 29, 2009 | 06:48 PM
beetle_orange's Avatar
^this was also a concern of mine hence i ordered the type A.
excalibur, if you look at the couplers there is a "buldge" in the middle of every coupler, this is meant for the "flexes" that can and will occur while driving the car.
Old Apr 29, 2009 | 06:51 PM
Excalibur's Avatar
You mean the oem ones? So go with them? Has anyone heard of issues with the one piece?
Old Apr 29, 2009 | 07:29 PM
THEMEMPHISFORCE's Avatar
The one piece pipe is fine, it is actually better to me after you think about it, the couplers that Nisei supplies are the ones you want to use they allow for flex. Plus a one piece pipe has less places for boost leaks, which you will have at first unless you tighten the **** out of the clamps. Use the stuff that comes with the pipe, you only reuse the rubber mounts, which is also another flex point and on mine I also put a small piece of rubber between the pipe and the front radiator support is what I would call it. The pipe rubs at that point and I didn't want to have to hammer that support in, so a small piece of rubber works great.
Old Apr 29, 2009 | 08:11 PM
the oem ones are straight rubbers, use the one nisei provides.
Old May 29, 2009 | 07:26 AM
Excalibur's Avatar
I hope I don't break anything. I'm notorious for snapping stuff.
Alright. I will be doing this today.
Old May 29, 2009 | 10:37 AM
Excalibur's Avatar
Just got done. It was an ultra-easy mod. Only hard part was tightening down the lower clamp and when I took the oem one off, the clamp fell behind the ic. I got it with a magnet and knocked it out. Decent little gain.
Old Jun 13, 2009 | 09:22 PM
speed650's Avatar
Ok, sorry for the newbie question here, but i just did an uicp swap and I now hear like a "hissing" sound when I get on it hard, like the way the turbo sounds when spooling but quieter, not sure if this makes sense. Is this what you guys call boost leak? Any help would be greatly appreciated.
Old Jun 14, 2009 | 05:44 PM
yes i would say you have a boost leak.
