Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Panel Air Filter
Old Apr 10, 2009 | 09:32 PM
Mj23foreva's Avatar
Panel Air Filter
This must be stupidest post in this section...I cant for the life of me get the Perrin panel air filter installed correctly, as a matter of fact I cant even put the stock one back in correctly....the stupid clip on the bottom of the box on the left side just would not lock in.
As a result I'm getting a wooosh sound like a blow off valve when I drive(or maybe thats what the perrin is suppose to sound like?). Either way I just cant get the bottom clips to lock in place. Any ideas?
Old Apr 10, 2009 | 10:14 PM
Deepseadiver's Avatar
wow! I just installed a K&N panel and had a bit of a time getting it in. Beacause it was at night with no light.
I don't remember there being any clips on the bottom. You just unclip the top one and slide out the old filter and install the new filter and clip the top back up. As far as the sound, you can hear the turbo spool up, and kinda hear the BOV.
Old Apr 10, 2009 | 10:20 PM
Mj23foreva's Avatar
then i really dont think you got it in right...there are 2 clips on the bottom that locks...you should double check in the morning
Old Apr 20, 2009 | 01:43 PM
Kajii's Avatar
bump
planning on getting the hks filter soon
Old Apr 21, 2009 | 07:44 AM
newcomer81's Avatar
if you have issues; there are 2 plastic screw rivets, 1 10mm bolt and 1 philips screw clamp to take off to be able to pop the whole intake box out. It would take less than 5 minutes to get it out and would give you very easy access to the bottom clips
Old Apr 21, 2009 | 10:24 AM
initialdrew's Avatar
Just to comfirm with one of the posts.....you need to wiggle the thing intake box for the bottom to lock in then you snap the top metal clips back.
I have the HKS drop in btw
Old Apr 23, 2009 | 10:57 PM
Kajii's Avatar
Just did it... that was easy.
Old Dec 14, 2009 | 06:43 PM
nlp187's Avatar
I installed my perrin drop in filter in under one minute no issues. haha.
Old Dec 16, 2009 | 02:38 PM
lamho's Avatar
is it neccessary to reset the ECU after drop in filter install? i'll be puting my HKS in soon.
Old Dec 16, 2009 | 03:04 PM
mlomker's Avatar
My AFE drop-in will not install/remove without unbolting the box, assembling the box in the air, and then working the whole assembly back in place. This may partially be due to my aftermarket turbo inlet but I think the AFE is simply thicker than the stock filter...
I assume you guys know to avoid oiled filters? Many people have gone through multiple MAF sensors since the oil comes off the filter and ruins it.
As far as the tune goes, nothing needs to be done. The gains are very modest when compared to a conical filter on a stock tune. If you get a custom tune then the drop-ins will flow well enough until you get to very big power levels.
Old Dec 16, 2009 | 03:20 PM
newcomer81's Avatar
It will take 16 min of idle and 16 min of cruise at a constant speed for the car readjust the ltft
Old Dec 16, 2009 | 08:52 PM
imboostinnow's Avatar
30 sec .. mod lol sorry btw that is how it is supposed to sound
Old Dec 16, 2009 | 09:58 PM
lamho's Avatar
would it be bad for the car if i iinstalled an aftermarket panel filter when the car is pretty new? i only have around 600KM on the car right now.
Old Dec 19, 2009 | 08:38 PM
toshibakoludo's Avatar
No it would not be bad. If that's what you want go for it.
Old Dec 22, 2009 | 08:02 PM
i64X's Avatar
Pull both sides of the airbox out, assemble it with the air filter outside of the car, throw the upper clamps on, and put the whole mess back in as one piece. That's the easiest way. It's one extra 10mm and the two plastic philips head screws that hold the air scoop to the radiator cowl and the whole front of the box comes out.
dcamp56
Oct 22, 2012 10:01 AM
vtluu
15
Feb 7, 2008 09:40 PM
ApexVIII
Oct 24, 2006 11:41 AM
Methodical4u
Oct 1, 2006 08:29 AM
dan628
Jun 3, 2006 02:10 AM
