Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
First Oil Change
Old Jul 18, 2009 | 08:21 PM
EvoXcrzy's Avatar
First Oil Change
I did my first oil change today!!! Use a genuine mitsubishi oil filter, and About 5.3qts of Mobil 1 synthetic oil. Everything was going good but now my oil pressure light comes on every i turn the key to the "on" position.... has anyone run into this problem? i did everything by the book and i have checked and recheck oil level on the dipstick everything is good. only one of the little hole in the dipstick is covered in oil. The every top one but not the bottom? It an 08 GSR. Need help!!!!
Old Jul 18, 2009 | 09:02 PM
EvoXcrzy's Avatar
I will check the oil level tomorrow with the engine cold... I can't think what else it can be. i read the manual and they only say to check oil level and take the car to the dealership.
Old Jul 18, 2009 | 09:09 PM
YzBrad99's Avatar
What weight mobil 1 did you use? How many little holes are on the dipstick?
Old Jul 18, 2009 | 09:58 PM
Daskid's Avatar
Did it say in the manual to put 5.3 qts? When I did mine, I roughly put 4.7 qts of 10w30, and that includes the oil put in the filter. I don't have my manual at the moment. For all I know, filling it below the rated level is better than over it.
Old Jul 18, 2009 | 10:25 PM
EvoXcrzy's Avatar
5w30. yes its like 5.32qts in the book. And two holes on the dipstick.
Old Jul 18, 2009 | 11:17 PM
AWDTerror's Avatar
remember not all of your oil drains out when you drain it from the pan. You will not use the full 5.32qts
Old Jul 19, 2009 | 05:04 AM
EvoXcrzy's Avatar
I rechecked oil level again, and everything is good?????? I am going to baby the car because i dont want to damage anything. i will recheck it later. i dont know why that Fing light is on!!! it only turns on when you go to start it and thats it!
Old Jul 19, 2009 | 05:31 AM
Clipse3GT's Avatar
I know Mitsu's have been known for faulty oil pressure sensor. Sometimes water gets in the connector harness and causes the oil light to come on.
Also maybe reset the ECTAS computer with the miles til next maint thing. Might be causing it. If you car is stock you can always take it to the dealer.
Which line is the oil level at. Top line/dot or the bottom line/dot?
Old Jul 19, 2009 | 02:06 PM
►EvolutionX◄'s Avatar
It comes on when you click the key over, but not when the actual car is started? if so this is how it should be working.
Old Jul 19, 2009 | 02:19 PM
EndlessRed's Avatar
uhm...yeah...every car i've driven before does that. camry, corolla, is350, 300, 330i, it's part of the startup check procedure. as long as it turns off shortly after you flip it to on (or start the car, whichever it was), it's normal. if there's a problem it stays on.
Old Jul 19, 2009 | 04:25 PM
YzBrad99's Avatar
When the car is running the oil light shouldnt be on.....until you start the engine the ecu thinks there is no oil pressure so therefore the oil will be on. (key at the 2nd position)
Old Jul 20, 2009 | 05:13 AM
EvoXcrzy's Avatar
I know what every car runs a self check at start up. It's not that. The multi-data display is showing the oil pressure light on. the oil is fill to the top line/dot. I will post picuters of what is going on. and i will take it to the dealership and ask. and repost that they said.
Old Aug 5, 2009 | 09:26 PM
Dr..Evo's Avatar
ive overfilled mine a bit and never had that problem. Thats weird maybe reset the ecu
Old Aug 7, 2009 | 07:28 AM
toredefine's Avatar
I'm thinking you overfilled it, mistakingly though.
Old Aug 7, 2009 | 09:40 PM
empirepb210's Avatar
it should only be 5 qt noob,
5.3 is if you take the oil out of the oil cooler and everthing
