Anyone knows how to do wheel alignments the X?
I tried looking for a DIY on how to do wheel alignments on the X and can't find one. Can anybody so kind enough to post detailed instructions on how to do both front and rear wheels? And tools needed? Basically, a full blown DIY.
This would be nice to know since wheel alignments from where I live goes about $100-$120 a pop.
I bet auto-X peeps can chime in.
Thanks!
Thanks!
Thanks!
Thanks!
*cough* bull****.
You need a camber gauge (accurate, not the bubble kind) and toe plates. I recommend longacre products.
Or you can go with the string alignment method. Google those items and you'll be on your way.
If you've never done one, helped do one or at least watched a tech do one up close, this is something you shouldn't be doing yourself. Pay the $150 for a lifetime at Firestone and move on.
I going to look into this now. As a single 4 wheel alignment averages 80-90 bones.
-Ethan
I don't really trust Firestone to touch my car. I've had good luck with the string alignment method, and I think I can get the toe more accurate than a Firestone tech would. For camber, you can do it with a carpenter square and ruler, or I recently switched to a digital laser level. It's definitely not easy, and will probably take you 3+ hours the first time you do it. Like others have said, it's much easier to just get a shop to do it if you trust them, but it's also not impossible (or even that hard really) to DIY. Just search here (evo 9 forums) or nasioc for DIY alignment threads.
I will look into that DIY. Thanks!
Wow... lifetime alignment for that cheap? Maybe you mean if you buy the tires from them and it goes with the lifetime of your tires? $150 is not a lot of money if you are talking about the whole lifetime of the car... they'd be losing a lot of $$$ if you keep your ride for 5-10 years lol, and have it aligned every year.
their is a dyi alingment, but very hard to do. and you have to put holes in the ground you doing it on. i learned it when i was in school and its not fun at all. its also not perfect at all so on a car like this i wouldnt recomend. to bad you guys arent around here. we only charge 89.99 for them and we have all the new machines.
