Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Need Boost/Vacuum in the cabin
Old Dec 9, 2009 | 11:23 PM
delkat's Avatar
What's the easiest way to get a vacuum/boost line into the cabin? I know I can run it through the fender well and in behind the kick panel. Is there an easier more direct route?
Old Dec 10, 2009 | 04:31 AM
hotdog's Avatar
There's a rubber grommet easily visible on the driver's side, that you can push aside and squeeze through.
Me, personally, I drilled through the firewall for my vacuum line, since I'm awesome like that.
Old Dec 10, 2009 | 08:33 AM
Bob Evolved's Avatar
the rubber grommet / through the fender well way is pretty easy....I would say it takes just as long as drilling a hole through your firewall and running the line that way
Old Dec 10, 2009 | 10:01 AM
MicMcKee's Avatar
I've always been a fan of using the rubber grommets...
Old Dec 10, 2009 | 01:04 PM
goofygrin's Avatar
on the passenger side behind the glovebox and sirius unit is a grommet you can go through as well. It's really easy to see on the firewall side. A bit of a pain under the dash/carpet though.
Old Dec 11, 2009 | 05:53 PM
pure_butane's Avatar
if your going with a mechanical boost gauge, i would recommend the most direct route, ie: drill through the firewall. you dont want all that vac line in the car.
Old Dec 11, 2009 | 05:57 PM
RallyGoneEvo's Avatar
I agree with drilling. The most direct line is best.
Old Dec 11, 2009 | 10:46 PM
delkat's Avatar
I need it for my Blaqops double pumper progressive control unit. It will get mounted in the glove box so the adjustments are accessable while tuning the car. It could also be mounted in the engine compartment.
The grommet on the firewall worked great. A direct path t'd off the diverter valve (BOV) along the top of the firewall and through the grommet into the glove box. Thanks for the tip.
I just pulled the grommet out using a long screwdriver on the engine compartment side then poked a sharp coat hanger through to see where the hole was behind the insulation on the inside. Then I removed the Serius unit to make room and made a little cut in the insulation for the tubing.
Old Feb 7, 2010 | 01:27 PM
cpunlamd's Avatar
Can anyone that has drilled a whole post pics from the fire wall side? It would be nice to see where we can start..
Old Nov 7, 2010 | 01:15 PM
daniel_f_us's Avatar
Where?
Where in the firewall did you go through?
I want to do the same but wothout damagin anything else. Any pics?
Old Nov 7, 2010 | 03:25 PM
mlomker's Avatar
He used the one behind the glovebox. In the engine bay it is behind the passenger side strut tower.
You can see a pic of it in my BlaqOPs install thread.
https://www.evolutionm.net/forums/se...-pump-kit.html
RedLanEVO
Oct 12, 2008 05:29 PM
mugen777
Sep 9, 2008 03:10 PM
CrackerJackToy
17
Feb 24, 2008 09:24 AM
NocturnalEVO
May 7, 2006 12:49 PM
use2vtec
Mar 9, 2005 09:59 AM
