Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Intake scoop removal
Old May 9, 2011 | 07:55 AM
evox1989's Avatar
Did anyone else have trouble removing the two plastic screws that hold down the intake scoop? I feel like my screw is just spinning even though the base is not moving.
Old May 9, 2011 | 08:00 AM
Zombie Killer's Avatar
Why remove it? Going CAI?
Old May 9, 2011 | 08:13 AM
Kracka's Avatar
Use a tiny flathead screwdriver to help pry the plastic screw head up.
Old May 9, 2011 | 09:50 AM
evox1989's Avatar
I'm going to put in the hks rs intake. Is it an actual screw, or is it a clip?
Old May 9, 2011 | 10:24 AM
Wrex1977's Avatar
It's a clip. You pull up on the middle section with a tiny flat head. Then you can remove the entire thing. These clips are like anchors you put in the wall for srews. The middle expands the bottom holding it in place.
Old May 10, 2011 | 09:11 PM
tdotsnipe91's Avatar
was also having the same problem this evening. one screw came out fine the other kept spinning and i couldn't pry it out
Old Jun 24, 2012 | 01:47 PM
Doctor Murdock2's Avatar
These things are giving me an issue as well, tried to pry the middle part up and it just broke haha
Old Jun 24, 2012 | 03:41 PM
pool playen bob's Avatar
when you unscrew it don't put any pressure on it. just simply pull up keeping pressure off the screw and unscrew. it should back out enough to get a screw driver of some kind under it to help it the rest of the way.
or drill the bastard out and install a different style clip.
hutch959
Dec 29, 2016 06:24 PM
stikllr13
51
May 17, 2013 02:52 PM
beetle_orange
Jul 5, 2012 07:39 PM
mksevo
179
Nov 15, 2011 03:34 PM
Turbo_M5
Apr 13, 2010 10:29 PM
