Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Installing the "EvolutionX" Trunk Badge
Old Jan 4, 2012 | 04:21 PM
JRally's Avatar
So yesterday after work I picked up an eBay style "EvolutionX" trunk emblem from a local guy who had an extra. My plan was to wash the car on the way home and then install the emblem, but the carwash was closed by the time I got back to my side of the town.
So I opted to wash the trunk in the garage and do it anyways...
1. I started by removing the Mitsu emblem. To do this I warmed up the trunk with a heat gun being careful to keep moving around and not melt the badge. Then I took dental floss and slid it under the emblem to remove it.
2. With that removed, I cleaned the trunk. I used a squirt bottle with some soap/water in it to wash it and then used goo gone to remove the adhesive residue from the old emblem. Then I used some polish wax and a buffer to remove any ghosting from the old emblem.
With the trunk all clear, I then used Acetone to clean it and remove any wax that was on the car.
3. Next step was to begin placing the letters. These came on a backer, but were cut into 3 pieces, and none of the letters were straight, so with the eBay ones, you're forced to do it one by one. I should also note that as I did these, I used the heat gun to warm the trunk. Since it was cold outside, I figured having a warm surface would help the tape bond.
I did some hunting around alot of threads and basically everything I could find on the OEM UK badge and google image searches and found that the outside edges of both of the O's matched up pretty well with the edges of the third brake light.
I taped some height lines above and below where the letters would sit and placed vertical tape at the edges of the third brake light to create a box where the letters OLUTIO would sit.
I then placed the two O's at the far edges of the box I created with tape. After alot of attempts at doing the math, and eyeballing the spacing, I figured out that the spacing for how I had set it up was about 21/32" (just over 5/8" by a 32nd). I continued and placed the LUTI based on that spacing.
3. Now it was time to install the EV on the front. These two letters are taller than the rest of the emblem as if to be tall caps letters.
I did some looking and found out online that the V is supposed to line up so that the top of the V and the Top of the O are on the same line, so that the V hangs lower than everything else.
I also found that the E went the other way, so that it lined up with the O's bottom edge, and stuck up higher than the rest. I matched the spacing and applied those
4. The N installs just as the OLUTIO did, match the spacing and stick it on.
5. The X is a little more tricky. I re-applied my top edge tape line across the top of the letters and over to the tail light. I notched the tape so that the tip of the X had room to be installed.
If I measure from the tip of the E to the tail light, I was measuring around 3.25", so I chose to use that as my reference and put the X about 3.25" from the other tail light, to finish with an even/centered look. The spacing between the N and the X worked out well because of this.
Finishing step was heating everything with the heat gun lightly just to make sure the adhesive was grabbing nicely.
Here are a few shots of it finished. I found that I fudged the L a little and might move that later on, it just needs to shift to the right slightly.
Old Jan 4, 2012 | 05:51 PM
guswaym's Avatar
looks good nice work
Old Jan 4, 2012 | 10:01 PM
AFD's Avatar
AFD
Looks great, and A++ for the detailed how-to
Originally Posted by JRally
did some hunting around alot of threads and basically everything I could find on the OEM UK badge and google image searches..
Just wondering.. why does every UK Evo X from the FQ-300 to the 400, that I've ever seen, have the "Evolution X" badge in the lower left-hand corner? Even Mitsubishi-cars.co.uk have the smaller badge in their photos.. and I just checked - Top Gear UK S11-E02 also had the same.
The only ones I've seen large and centered, like yours, have been done by guys here in the US. It looks nice and all, but am I missing something?
Google image search for "boot" and "fq-xxx"..
Old Jan 5, 2012 | 03:56 AM
mirkendargen's Avatar
Is the clearcoat/paint not acetone-soluble? I about choked when I read that hoping you didn't jack up your paint
Old Jan 5, 2012 | 05:01 PM
JRally's Avatar
Short answer yes, but not enough to worry about if you do a light wipe and then immediately dry it out with heat.
Old Jan 5, 2012 | 10:44 PM
TEMPELIS's Avatar
it might be just me, but i think your "E" is higher than the rest of "volution" lol
Old Jan 5, 2012 | 10:47 PM
SaulHudson's Avatar
Yeah that E is off.
Looks really good though.
Old Jan 5, 2012 | 11:05 PM
GdotRegEvo9's Avatar
E is slightly higher
Old Jan 10, 2012 | 08:14 PM
keshav707's Avatar
not liking the red look.
Old Jan 10, 2012 | 08:18 PM
JRally's Avatar
The E is not off, its dead on.
Perhaps the image is deceiving, but its all lined up.
Old Feb 26, 2012 | 04:39 PM
anb3695's Avatar
Looks good
Old Feb 26, 2012 | 05:19 PM
b00sted4banger's Avatar
Lol yea the E is def off. Looks good though
Old Feb 27, 2012 | 03:43 PM
JRally's Avatar
It's not, but whatever.
Old Feb 29, 2012 | 06:47 AM
Diversion's Avatar
The "V" is more off than the "E" is. The bottom of the V should have been lined up with the remaining letters to look more even.
Old Feb 29, 2012 | 08:21 PM
JRally's Avatar
Can I unsubscribe from my own thread...jesus.
Yes the photo is deceiving, no it isn't crooked. I've checked checked and re-checked like a million times. I see the car daily and the emblem is exactly as it should be.
