Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Upgrade Engine Oil Cooler
Old Feb 9, 2012 | 07:15 PM
amsevoixmrse's Avatar
Post Upgrade Engine Oil Cooler
Did anybody installed aftermarket engine oil cooler on same location as stock cooler ?
I'm thinking on how to do it and with what size cooler I can or should go.
As of right now I'm thinking about getting Setrab 50-625-7612 model and still don't know what fittings to get and size hose.
any kinda help will help .
I can't afford on getting SSP cooler or Map. I checked them out and they are sweet pieces. Almost ready to go, plug and play stuff.
after I do it I'll post pix on here in this Thread.
Old Feb 10, 2012 | 10:03 AM
So far on my research I got advise to go with AN-10 fitting and if I use 19 and higher rows and if placing cooler sideways , advise is to plug oil feed into lower inlet and output on top . That's for making sure oil fills up whole cooler.
Old Feb 12, 2012 | 06:30 PM
AWDralliart09's Avatar
Why plug the feed on the lower, just meens the pump has to work that much harder??
Hey do you know what kind of oil pump in the evo X?? just wondering because Im about to intall the evo x cooler on my RA.. just wondering if you know..
Great idea on the upgrade cooler though, if you do with success, I plan to copy cat your project.. Been wondering about this for some time now..
thanks and keep it up!!
Old Feb 25, 2012 | 04:50 PM
nomad's Avatar
The reason it feeds from the bottom is so it fills up the cooler. If it feeds from the top the oil pump will pull it thru the cooler to quick and the oil will not get proper cooling. It's the same concept as a radiator, it pushes coolant/ water thru the motor and to the bottom of the radiator.
Old Feb 25, 2012 | 10:57 PM
andy5notarobot's Avatar
I made my own for about $350 I used M18x1.5->-8AN for the block and -8AN lines to the oil cooler. Fairly easy. I mounted up front on my crash beam. If you go this route, use banjo bolts to the oilcooler, the 90* fittings sit real close to my bumper, I will swap over to banjo bolts there when ever i decide I don't want to be lazy anymore.
Heres a few pics, so you get the idea of what I'm talking about. FYI, don't use push-lock hoses, opt for Braided flex lines. I'll be swapping mine over eventually.
Attached Thumbnails Upgrade Engine Oil Cooler-dsc_0146.jpg   Upgrade Engine Oil Cooler-dsc_0033.jpg   Upgrade Engine Oil Cooler-dsc_0020.jpg
Old Feb 29, 2012 | 01:34 AM
OK, My Project went well. It was easy to install cooler and fittings on hoses.
My parts list:
Setrab oil cooler 625 model
1 Setrab 90* fitting 22mm to AN-10
1 Setrab fitting 22mm to AN-10
2 Straight AN-10 hose ends
2 90* AN-10 hose ends
2 18mm 1.5 thread to AN-10
6 feet Flex-hose AN-10
Total came up to $332
Attached Thumbnails Upgrade Engine Oil Cooler-img_1306.jpg   Upgrade Engine Oil Cooler-img_1307.jpg   Upgrade Engine Oil Cooler-img_1315.jpg   Upgrade Engine Oil Cooler-img_1319.jpg   Upgrade Engine Oil Cooler-img_1320.jpg
Old Mar 1, 2012 | 08:12 PM
Red Dragon's Avatar
^ how much did you end up spending?
Old Mar 17, 2012 | 01:20 PM
So I've started my oil cooler on my Ralliart. I have the stock evo x cooler, but I'm having a problem with the thermostat. When I install the thermostat there is a slight gap present, like there is supposed to be an o-ring or washer on it. So my question is there supposed to be a small gap or do I put an washer/o-ring on the thermostat?? And do I even need the thermo or can I just leave my plug in there? I don't think it would make much difference if I just leave the plug.. But then again my thinking has got me in trouble before
Old Mar 22, 2012 | 10:22 PM
Bveirs's Avatar
Like it.
Old Mar 17, 2013 | 11:57 AM
Kirbyryu's Avatar
Mishimoto makes a dual oil cooler kit for the X and mounts in the stock location and all lines and fittings come with it they even have a youtube video on the installation
Old May 17, 2013 | 02:53 PM
faeskoni's Avatar
Like like like
Importsnrice
Jul 20, 2015 10:47 AM
wizechef
Jun 13, 2015 06:53 AM
gIGoN
Oct 25, 2013 05:34 PM
pearldevo8
Apr 3, 2013 08:24 AM
omniprobe
Mar 12, 2008 04:17 PM
