Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
help!! front bumper and grill removal!!
Old Mar 13, 2012 | 09:26 AM
si00dcracer's Avatar
Hello guys,
I need your help in taking out the whole grill , fog lights ,emblem and trim on the bumper. Bout a few months back, while cruisin in the freeway, i hit a raccoon and ruin my right fog and crack my bumper.. called the stealership and ask for how much for a new one and its almost a grand unpainted. I also ask a few body shop here in frisco and believe me its better to buy a new one than to get it fix. So i searched around the net and found a pretty nice priced bumper from a site in the east coast. My question is , is it pretty hard to remove all the trimming in the nose of the bumper?? Has some body
In here posted an step by step ? Again, dont wanna ruin the clipsor whatever that hold the grill etc. Thanks in advance
Old Mar 13, 2012 | 09:30 AM
jkc213's Avatar
Its very easy.. I know there's some how to's on this site.. Just search around.
Old Mar 13, 2012 | 09:32 AM
escodotcarter's Avatar
the black plastic part in the middle of the grill that the emblem is attached to is the hardest thing to remove. its as if mitsu never wanted that piece to be removed. You will definitely break a few bracket/clips but it is possible to remove. you need two people also. lost of things that you need to bend out of the way to get to screws bolts etc.
Old Mar 13, 2012 | 09:34 AM
haha we must not be talking about the same thing.
Old Mar 13, 2012 | 09:40 AM
J Dog's Avatar
Removing the bumper is pretty easy...takes me about 15-20 minutes to do it once the front is up in the air. I elevate the front and have the wheels at full lock in one direction as it gives you better access to 3 clips and a bolt in the wheel well on each side.
You can use these directions to get the bumper off...
https://www.evolutionm.net/forums/ev...lustrated.html
As far as taking the grille off...haven't done that yet but plan to when I delete the front emblem in the coming months. Looks like the grille and other things are just held on by screws and whatnot so you should be able to yank things off once the bumper is off.
Old Mar 13, 2012 | 10:09 AM
I've seen the video on how to remove thebumper, it looks pretty easy. What im concern about are those trimmings and grills. Just finish searching the forum, did not see any instruction and diagram on how to remove those. Just wanna be safe and not break anything while swapping the pieces to the new bumper.
Old Mar 13, 2012 | 10:19 AM
The bumper im trying to get is just the painted part. All of the black plastic in front and grills would be remove fromthe old one and put on the new one. Just want to play it safe nd not break anything in the process. I thought that removing the black plastic surround on the grill(chrome on mr) would come off as the entire front piece.
Old Mar 13, 2012 | 10:33 AM
J Dog's Avatar
Gotcha...I don't know if that middle part is removable but I haven't looked at it that closely so can't give you a definitive answer. You're best bet would be to remove the bumper and examine it to see if it's even possible.
I would assume (total assumption) if they sell the bumper without that middle section it must be removable then.
Old Mar 14, 2012 | 04:09 PM
jkc213's Avatar
U can remove every piece on the bumper.. I got the seibon "S" style bumper cover to get rid of my front emblem.
Just remove the bumper and u can figure it out from there.. GL
Old Mar 17, 2012 | 07:47 PM
Thanks jkc213.. was it hard for u to take out those pieces? Just ordered mine the other day and i guess there no way of going back. The body shops here are like the stealerships... they will take ur arm, leg and evreything in between to fix a fixable part of a car...
Old Mar 23, 2012 | 05:53 PM
jkc213's Avatar
Don't waste your money, u can do it by yourself.. Just take your time..
Old May 21, 2014 | 10:53 AM
Verbal21's Avatar
Sorry for the gravedig but my front bumper cover is cracked and since I need to replace it, I was looking into getting the EVO-R CF front bumper cover but can't seem to figure out how to remove it. Do I just pull it out by force?
It's the CF piece in the middle.
Old May 21, 2014 | 06:54 PM
beetle_orange's Avatar
U use some long nose pliers and compress them the middle portion will pop right off and just take them out, reuse when installing the center grille. Bumper needs to be off the car.
Old Jun 13, 2014 | 02:16 PM
Chang_Wufei_05's Avatar
Just did this the other day and can provide some detail You'll need to take the bumper off to remove the center grille or grille surround. Once you have the bumper off, it's easy but time consuming as there are about 40 philips screws holding the surround to the bumper and the center piece to the surround.
Steve?
Apr 21, 2016 04:15 AM
RallyGoneEvo
45
Dec 2, 2014 01:51 PM
Krakker
Outlander Sport
Aug 24, 2014 06:57 PM
mossontree
Aug 19, 2013 09:10 PM
sE DegeN
Jan 16, 2011 11:01 PM
