Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Rexpeed vortex gen evo x question
Old Jun 17, 2012 | 07:44 PM
Alpha X's Avatar
Installed mine about a week or so ago... got up to about 140mph at a track and it didn't fly off
So far so good. Btw I used all of the 3m tape they provided.
Old Jul 1, 2012 | 12:07 AM
Revolution9mr's Avatar
it looks really good man
Old Jul 1, 2012 | 08:47 AM
an0therh22's Avatar
noe18s is probably as good as it gets for rexspeed.
Old Jul 24, 2012 | 08:40 PM
AntiVirus42's Avatar
Originally Posted by opium
wish i read this thread before installing it back in jan... G'damn thing flew off my roof when i hit 100mph! Lost it on the freeway
+1
Old Jul 24, 2012 | 09:11 PM
SamsonEvoX's Avatar
Originally Posted by evo 1768
3m tape [IMG][/IMG]
It seems to me that the leading edge of the Rexspeed VG would hurt laminar flow on the trailing part of the roof and could upset the effectiveness of the rear wing. The factory MR VG leading edge was smoother and more beveled at the leading edge:
http://www.motortrend.com/roadtests/..._05.html#photo
Here are some technical papers done by Mitsubishi engineers for the Evo IX Vortex Generator and the Evo X roof and wing design:
http://www.mitsubishi-motors.com/cor...004/16E_03.pdf
http://dl.dropbox.com/u/10199204/20e_08.pdf
For the OP, 3M makes very high adhesive strength double faced tape. I used this when I mounted a Mugen wing to my 2007 Honda Civic along with the fasteners provided. Provided a really tight seal. At Wal-Mart, you can find various degrees of adhesive bonding for the double faced tape. The stuff I used has a red film that you peel off.
Old Sep 23, 2012 | 11:17 PM
TINGER's Avatar
Originally Posted by Noe18
is it me but looks like the right is lower then the left
I just noticed everyone on your street has a SUV or pick-up. Well except for that one white sedan in the end.
Old Sep 24, 2012 | 05:40 AM
SUBIIKILR's Avatar
That VG looks great
Old Apr 16, 2013 | 07:58 PM
ufcgsp27's Avatar
looks good, wish they made painted ones that fit 9x5 antenna and no roof bumps...
Old Apr 17, 2013 | 03:32 PM
WWkevoX's Avatar
wish I saw this thread before I tried installing my rexpeed vg a month or so ago. I literally have the same issue as the op did. currently the vg is sticking up a little on the driver side on my car, but after some of my own attempts gave up. It still bothers me looking at my car but I'm cooping.
Old Apr 17, 2013 | 04:26 PM
bobby0283's Avatar
I bought mine from another EvoM member. The hole for the SSS antenna was a bit small so I had to sand it out a bit for it to fit. I bought a roll of the 3M Automotive tape, that seems to hold like cement. I installed mine on a hot day, left it sit out in the sun to give it some flex then stacked some weights on top of a towel and put those on the corners when I installed it. One corner does still pop up a bit, but it seems to be holding fine otherwise...
Old Apr 22, 2013 | 01:01 AM
llno24's Avatar
I've given up on 3M tape altogether. Go get some butyl tape. This stuff is a malleable tape that is like soft gum when it gets warm.
To put it on you need to warm it up a bit and basically mold it onto the side you want attached to your car. Make sure that you put it thin enough that it doesn't just stick up and leave a gap. In areas that seem to pop up use a little more to make it level. Once you have the butyl tape all spread out, press it down and use a cloth on the top of your VG to press onto the car. Use some pressure to make sure the VG stays on. If you have a heat gun give it a couple once overs to warm the butyl tap under the VG and apply pressure again.
If you are still worried that it'll come off... I suggest that you use both 3M tape and the butyl tape.
Old Apr 23, 2013 | 05:33 PM
EricRoan's Avatar
http://www.lowes.com/pd_394705-98-41...tape&facetInfo=
Scotch 1-in Two-Sided Tape
-Holds up to 10 lbs
-Weather-resistant, double-sided tape works on a variety of indoor and outdoor surfaces such as painted cement or brick, glass, wood, metal, tile, ceramic, and more
-Faster, safer, and more versatile than nails and screws
good stuff!!
Old Jul 21, 2014 | 04:02 PM
TxFAkuma's Avatar
What is the STRONGEST 3M tape i can get for this? Where can i get it?
Old Jul 22, 2014 | 09:07 AM
ogrenator's Avatar
very strong stuff..
Amazon.com: Scotch 414P 1 by 60-Inch Extreme Mounting Tape: Home Improvement Amazon.com: Scotch 414P 1 by 60-Inch Extreme Mounting Tape: Home Improvement
I use the stuff below with no issues on multiple parts on the car...
Amazon.com: Scotch Permanent Outdoor Mounting Tape, 1 Inch x 450 Inches (4011-LONG): Office Products Amazon.com: Scotch Permanent Outdoor Mounting Tape, 1 Inch x 450 Inches (4011-LONG): Office Products
Old Jul 22, 2014 | 01:01 PM
TxFAkuma's Avatar
What did u use to sand it down?
Rexpeed
Evo 'For Sale' Exterior Styling
640
Jun 19, 2019 08:20 PM
boostedmkiii
Jun 28, 2016 06:21 PM
Hakmeister
Dec 18, 2014 08:28 AM
Sol-Good
13
Jun 8, 2014 10:43 PM
evilution8
Jul 21, 2008 12:06 PM
