Any Help on a Clutch Instal????
So I got an Exedy Twin Disc Clutch for my 2010 Evo X GSR and had a local shop install it. The problem, the awc/traction control service light keeps coming on. I think something didn't get hooked back up a sencer or something. The car is back at the shop and I'm trying to help them figure it out so I can get my X back. Anyone run in to this problem after a clutch install or at anytime for that matter? Any info for this shop would be helpfull thanks.
Let's see.
I had same issue with you after installing clutch
two ways to do it.
Go to dealer and spend money
or
Do ghetto style acd pump bleed.
You will need two people for this job
Make sure you have 4 nice jack stands.
ATF tranmission Fluid (I used AMSoil ATF)
1. jack your car up enough to rotate front tire. Make sure car is stable on jack stands.
2. side break off
3. Start the engine
4. Bleed front ACD pump while another person rotate front tire
This will kick ACD pump on.
5. After bleed, check fluid level. (in trunk)
Hope it helps
two ways to do it.
or
2. side break off
3. Start the engine
Hope it helps
Thanks all I gave the info to the shop I had it in and they got it. Funny thing is that they said that they under quoted me and next time i have them do the clutch they are going to charge me more. But they told me the same thing last time i had it in their shop. HAHA i wonder if they will remember next time, and the way i drive it, (like i stole it) there will be a next time.
evoxisking
Jan 22, 2016 06:43 PM
bryanlo
10
Apr 9, 2014 10:40 PM
