Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
EVO X MR DRL re-pin (for those having issues with LED's)
Old Feb 19, 2017 | 09:47 AM
  #31
joseph_mills's Avatar
Huge thank to Bike Mech for this! Knocked in out in a few minutes this morning. No more ugly DRLs!
Old May 9, 2017 | 06:09 PM
  #32
Lightsaber's Avatar
Originally Posted by Bike Mech
Starting on the Driver's Side we will be swapping the light blue and the black wires.
I recently tried following this guide and found there is a minor error with it. The wires to switch should be light green and black, not light blue and black. Nevertheless, this is a great guide.
Evo X DRL wiring diagram
Re-pining the DRL wire harness
After swapping light green and black, it works
Old May 13, 2017 | 09:33 AM
  #33
sonny_x_gsr's Avatar
Thank you for this guide!
Saved me a bunch of headache when my DRL didn't turn on after switching to LEDs on my 2014 evo x w/SSS package.
Old May 21, 2017 | 09:19 PM
  #34
europaul's Avatar
Thanks for the instructions. I did it today and it worked great. Just like the member above stated on the driver side the cables to switch are light green and black (not the light blue) on my 2012 Evo X MRT.
Old May 31, 2017 | 11:41 AM
  #35
Cflo23's Avatar
5 Year Member
I purchased DRL from super bright leds, they were literally plug and play (no need for repining etc.) in my 2015 X MR.
1156 LED Bulb - 27 SMD LED Tower - BA15S Retrofit
https://www.superbrightleds.com/more...retrofit/2622/
Old Jun 3, 2017 | 06:22 AM
  #36
b00stedturtle's Avatar
Thanks for the write up!
Old Jun 16, 2017 | 03:30 PM
  #37
Vinocj's Avatar
Thanks for this, it was a big help
Old Aug 8, 2021 | 10:22 AM
  #38
Inside_line's Avatar
Bump for an incredibly useful post. This saved me installing a pair of Sylvania 1156SLBP2 LEDs where normal 1156 bulbs go into the DRL. This was a 2014 GSR with SSS. They LEDs would not light when originally installed, so the polarity is definitely an issue on these bulbs. Thanks!
Old Dec 26, 2021 | 11:56 AM
  #39
BenMara's Avatar
5 Year Member
i picked up LED DRL from Lasfit never had any problems.
Old Mar 6, 2025 | 03:47 AM
  #40
Arnold Evo X MR's Avatar
As I've read there are quite a few of us out there with factory HID's that have -14vdc going to the DRLs. This limits what we can buy or install. I did like many others and ordered LED's that were made to be bi-polar (pos or neg. polarity). For some reason they kept blowing on me. I couldn't get more than 1 day of use out of them. I figured it had more to do with the negative polarity than anything else. I've read about loose grounds but this is a plug and jack setup so that didn't sound right since there was no place for a ground to be tightened.
Being kind of cheap and not liking to be limited on my choices... I decided to consider cutting my harness and reverse the wires. But for some reason having a chopped harness bothers me more than rolling fenders swapping turbos etc. It just seems ghetto to me.
So without further adieu..... This is how to do it right.....
So before we start these are the tools I used. Two jewelers screw drivers
This is one of my cheap ebay bulbs I bought for under $5/pair.
Note: The DRL plug is next to the large plug on the headlight. You can find it easily by following it back from the bulb cover. It has about 6 wires coming out of the back of it even though we only use two. You can pull it apart by squeezing the clips and pulling on the plug not the wires.
gently pry up the retaining clip and remove it. Don't lose it you'll need to put it back in when your done. This keeps the pin locks in place.
In side here there are small plastic tabs that hold your pins in place. They rest up against the metal pins inside. Very carefully you're going to slide your smallest screwdriver in there to lift them away from the pin. DO NOT put any pressure on these guys cause they will break. You literally just slide your screw driver in there. You won't even feel them snap open.
When your screw driver is in there you can then just pull the pin out of the rear of the plug.
Now do the same for the other wire.....
Swap their positions and push them back in.....
Be sure to place smooth side out. You'll actually feel a very light snap when they are seated. If need be, you can push them in with one of your screwdrivers.
Be sure to put the retainer back in. Snap everything back together swap out your bulbs and test fire.....
Much of the same on the passenger side but with the water bottle in the way it took one extra step.... And here we will be swapping Black and Yellow wires.
Because the water bottle was in the way I couldn't pull the wire out by hand so I used the small one to release the pin and the slightly larger one to push the pin out.
All done and working. And best of all no wires were harmed in the making of this film ha ha ha
I Need also the DRL reley in the fuse box? Or Just the fuse ?
xXANCHORMONXx
Apr 5, 2024 01:01 PM
ryukinevo
For Sale - Part Outs
330
Aug 31, 2020 09:48 PM
kobi411
11
Oct 31, 2017 07:07 PM
ryukinevo
114
Apr 18, 2017 06:35 AM
ryukinevo
35
Mar 29, 2016 12:09 PM
