Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Bumper removal question
Old Apr 26, 2014 | 11:08 PM
butters149's Avatar
I removed the bumper once before but I broke one of the small tabs on the side that is connected to the fender (there are like 5 of them still). It sounded so harsh when I pulled on it.
What is the correct way to remove the side of the bumper? A couple people said to "pull down" on it, but I don't get it since it seems that the only way to unsnap the bumper is to pull it out horizontally hard.
Old Apr 26, 2014 | 11:41 PM
Treyzian's Avatar
Honestly, just do it smoothly and slowly. I've removed and reinstalled my bumper almost 10 times this month already and I've yet to have any issues with tabs breaking.
I pull out laterally, at a slight downward angle, but I don't really think the angle matters.
Old Apr 27, 2014 | 09:08 PM
GSRSTIKILR's Avatar
Veteran: Army
You just need to be "smooth" about it. Don't jerk it out or anything like that.
Old May 5, 2014 | 03:19 PM
ikt's Avatar
ikt
the only part you would pull "down" would be the very last hole towards the fender well because it slips over a square body grommet that holds a 10mm bolt. The rest you just pull straight out.
if you broke the plastic clip that goes on the car itself, it's like $18 bucks from the dealer and is only two 10mm bolts
if you broke a tab on the bumper cover, what you do is go get a SEM bumper repair kit, cut the fiberglass tape into a 2"x3" square with plastic behind it (this all comes with the kit). Put the glue on the tape, and fold the tape in half over what remains of the torn bumper tab. Let it dry for 90 minutes, trim with scissors and drill a new hole.
Old May 5, 2014 | 03:56 PM
APEXR's Avatar
Saw this thread right above yours.
https://www.evolutionm.net/forums/ev...r-removal.html
Old May 8, 2014 | 04:45 AM
elecan's Avatar
I've managed to brake off a tab when I was in a hurry.
I believe it's 62002R for right side and 62002L for left side, might want to double check it though.
And as said before, just be gentle with it and it will pop out
Old Feb 19, 2015 | 08:24 PM
e85_evodiction's Avatar
nice
EVO8LTW
Nov 4, 2016 06:29 AM
saytheb
12
Oct 20, 2009 02:53 PM
SilverEvoX
Jan 15, 2009 03:04 PM
aj_pierce
Lancer How Tos / Installations
Aug 31, 2007 07:04 AM
Ink
12
Jul 25, 2006 06:59 AM
