Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
How to disconnect ayc pump - please help
Old May 11, 2024 | 06:57 PM
Jahtoot's Avatar
I’ve searched and haven’t found anything on how to disconnect the ayc pump. I see two electrical connections at the pump in the rear passenger side. Do I just disconnect these and the pump will be turned off?
I am going to flush my transfer case because there is fluid coming out the breather hole only when I drive the car.
i am thinking the acd seals have failed which caused this. So I want to disconnect the pump so it stops sending fluid to the TC.
when fluid is added to the trunk Reservoir it goes down and the only leak is when the car is driven (through the breather hole)
this is for a 2010 evo X se - SST trans that’s was rebuilt by jacks recently.
Any advice is appreciated thank you !
Old May 12, 2024 | 10:35 AM
Jaraxle's Avatar
All your answers:
Evo and Tuning Resources (evoscan.com)
Old May 12, 2024 | 11:13 AM
Jahtoot's Avatar
Thank you. I am a novice/enthusiast (not a mechanic) so this should give me some thing to read and learn from lol.
I can do basic things like fluid changes and suspension/brakes maintenance.
so this will be a new challenge for sure.
I am guessing I need to read up on the section with remove/installing the SAWC pump.
Old May 12, 2024 | 05:59 PM
Jahtoot's Avatar
https://www.evolutionm.net/forums/ev...-question.html
search works! Ty as well jaraxle
Turtletron
Sep 22, 2021 11:01 AM
Devesh Budhram
Dec 30, 2016 03:21 PM
dave_evolvix
11
Nov 27, 2013 06:48 AM
eddy5201314
Sep 5, 2013 08:34 PM
blaze_125
Lancer Troubleshooting
Mar 2, 2006 12:04 PM
