The Ultimate Aggressive Wheel Thread... Evo X Style
^^This is one of the things I fear when going with a stretched tire. Breaking the beed on the side wall would be disasterous at high speed. But you gotta do it with such an aggressive offset, the only other option is running a ton of negative camber but then you will tear up the inside of the tire.
If those 18x10.5 RPF-1s only came in a +20-25 offset it would be perfect.
That's a little crazy considering 275 already looks stretched slightly on a 10" wide rim ... (using Yokohama, they seem to be a bit more narrow compared to others) If I were on those RPF's I would find a way to use 265 at least.
