The Ultimate Aggressive Wheel Thread... Evo X Style
Volk TE-37 (no they are not Rotas
) 18x10.5 + 15
Project Kic's 10mm spacer in rear
-2.5 camber front and rear
265/35/18
Rear fenders rolled and pulled
Front - slight roll and pull, chopped off protruding part of fender lining
Fortune Auto coils
What do you think?
<Images Deleted>
Hey, its my first post!
) 18x10.5 + 15Project Kic's 10mm spacer in rear
265/35/18
Fortune Auto coils
What do you think?
<Images Deleted>
) 18x10.5 + 15
265/35/18
Fortune Auto coils
What do you think?
265/35/18
Fortune Auto coils
What do you think?
Car looks great but is it even streetable at that ride height or was that only for pictures? Looks like less than 1 finger gap in the rear and tucking tire in the front. Also why would you run a spacer in the rear on a 18x10.5" +15? It already sits past flush with that offset. What's your clearance in the front about 2"?
I'd lower mine more but not that low, couldn't clear a speed bump to get into the parking garage at the office lol.
i run the same wheels size and offset.. the rears definitely do not need any type of spacers... lol its flush as is... but more power to you for having it HERRA FRUSH!
So I've been thinking on what size wheels I should get.
It's between 18x9.5 +12 (255/35/18) vs 18x10.5 +22 (265/35/18)
Currently I run -2.3 front and -2 rear. Non rolled fenders, I'd like to avoid rolling fenders.
I'm also running on Eibach Pro Kit Springs, I don't recall the number of the drop on those thing.
It's about a 0.5" more than Swift Springs if that helps.(Guessed)
Well, anyways let me know if you think I can pull off 18x10.5 +22 w/ 265's, and -2.3F and -2R camber.
Thanks!
Thanks!
Thanks!
Thanks!
I also have a monster incline in my driveway, most speedbumps and inclines just take patience. I ran a spacer in the rear because I could stick my hand in and feel my rolled fenders still... just didn't seem pushed out enough. Honestly, to me the car is not that low, it is 2" clearance in the front but because of the way the X is designed, the sides and rear have tons of room.
Thanks!
Thanks!
-relieve the constraint of wheel/tire sizing based on your fixed ride height.. in other words - get the wheels you want (based on performance/price criteria I assume)
-have the ability to go lower without fear of rubbing, scraping, etc since coilovers are much stiffer
-everything else that makes coilovers > springs
that being said, based on my judgement from eibach springs (my car came with these as a surprise, everything else was bone stock, even the dealer didn't know it had lowered springs on it, and it being the only X on the lot I assumed it came at that ride height
) and my wheels/tires which seem to only be +7 offset difference from you, I'd say you can just barely clear the non-rolled fender IF you run -2.5 ish camber in the rear.but you should roll your fenders, its good for you
Thanks for all the comments!
-Mike
