The Ultimate Aggressive Wheel Thread... Evo X Style
Old May 27, 2015 | 03:15 PM
  #4516
Evo X10's Avatar
Hey guys hate to be that guy. But the rims I am buying are
XXR 550 18x 9.75+ 19 5X114.3
The backspacing is what confuses me they are 6.125 will these fit the evo?
I seen someone rocking them but wasn't sure about the clearance on the brakes and wanted to know if that sounds right.
Old May 27, 2015 | 10:06 PM
  #4517
Bleackone's Avatar
Dont run a staggered fittment on an awd car, youll break it, for reasons i'm too tired to get into. ****in christ. Youll throw of the vtec.
Old May 27, 2015 | 11:57 PM
  #4518
SpeedI2acerX's Avatar
My bad I meant 18s not 19s. That's what I get for typing from my phone. Post corrected..
Originally Posted by juneil
Hmm. First: stock wheel is 18. You said, "I recently bought new tires for my stock wheels. They are 255/40/19." 19 will not fit an 18" wheel.
Second: size is 18X8.5. You said, "My question is I want to get 8x10 wheels and wondering if the 40 series will give me issues with rubbing? Will the 10 width stretch the tires?" No way a 8" wheel will fit on a Evo, son. And you wouldn't have to bother about stretching because the wheel wouldn't be tall enough to reach from the bottom of the inside of the tire to the top. It would be 10" too short.
Maybe you aren't familiar with your car and should do some research. But if you just threw those numbers out there, not consulting your owner's manual or looking at the tires, then you should trade the car in for a donkey. You couldn't **** that up. Then again, I guess you could by feeding it the wrong whatever a donkey eats.
But on a helpful note, and assuming that you are not dyslexic, maybe you typed in the wrong numbers?
Old May 28, 2015 | 12:00 AM
  #4519
Wait how is that staggered?
Old May 28, 2015 | 12:37 PM
  #4520
Evo X10's Avatar
yea its not staggered its the same size wheel all around. I was just confused about the backspacing if it will clear the brembos. I don't want order the wheels and tires only to find they don't fit and then I am out of luck cause no spacers for me.
Old May 28, 2015 | 04:55 PM
  #4521
Bleackone's Avatar
Sry, ur syntax threw me off.
Old May 28, 2015 | 05:00 PM
  #4522
Bleackone's Avatar
I never understood why people dont like spacers, anything less than a 15mm isnt going to damage anything. I ran 25mm on all four corners for two years and i didnt even need an alignment when i switched to my Advans. Its like i tell my kid, just try it ull like it.
Old May 28, 2015 | 08:08 PM
  #4523
juneil's Avatar
Lol. We forgive you. Yes, the 10" will stretch the tire. As for rubbing, I am not sure because a part of that will depend on the offset that you are running. Nothing that a little roll won't fix. I am running 18X10.5 with 275/35/18 and they are stretched. Had to go with -2 degrees camber, rolled rears, and cut a piece of the rear tabs to make it work. Had to bend the tab on the front fender and trim the plastic part of the bumper to make that work, too, but it still rubs when turning on louisiana's pristine driving surfaces in leesville. Trust me, these roads were made only for military vehicles! Oh, and the car is lowered on BC coil overs and lowered about 2.75" in front😊
Old May 28, 2015 | 10:55 PM
  #4524
Viegasjuice's Avatar
Spacer belong on show cars only IMO. i had ichiba 20mm spacers on my VIII with RPF1 wheels and hub centric rings. Installed properly and torqued correctly. Within 40 miles i noticed a horrible wobble. Checked my wheel and the spacer had backed out almost all the way. I could have died on the highway. Never again.
Old Jun 2, 2015 | 10:03 PM
  #4525
solelife's Avatar
Old Jun 3, 2015 | 12:08 AM
  #4526
kuronoko's Avatar
Old Jun 5, 2015 | 12:44 PM
  #4527
Xyster the 1st's Avatar
I'm barely making the agressive requirements set forth at the beginning of this thread, so I thought that I'd share.
Japan Racing Wheels JR-5 (18x9.5 +22) wrapped in Dunlop Direzza 265 35 R18. I'm on the stock MR suspension. I'm super pleased with the wheel fitment!!
Old Jun 7, 2015 | 06:37 AM
  #4528
R3VOLUTION's Avatar
GTWorx Springs
18x9.5+22 Work Emotion Ultimates. Need bigger tires IMO
Old Jun 15, 2015 | 10:07 AM
  #4529
Evo X10's Avatar
H&R lowering springs
Rota Grids 18x9+20
Tires Potenza 265/35/18
Old Jun 16, 2015 | 08:25 AM
  #4530
r34p3rex's Avatar
Rota Grids 18x9+20
What lip set up do you have?
