The Ultimate Aggressive Wheel Thread... Evo X Style
Old Jan 24, 2010 | 08:24 AM
  #1441
LRM1981's Avatar
Originally Posted by GGevoXftmfw
How do you like the gunmetal rpf1's? First pics ive seen with gunmetal, I was thinking about getting them in the same color and offset but 9.5s. See if u can take a few more pics of the gm on gg, i was worried about it blending in too well. You like the color over black you had?
I like them, they are a little lighter in color than i was expecting, but they do look really good with the GG color. The pictures I posted with my crapy camera don't really do them justice, they look much better in person. Black gives you more of a contrast, but this lighter gunmetal is growing on me and I've got a lot of compliments.
Old Jan 24, 2010 | 08:41 AM
  #1442
cpunlamd's Avatar
Originally Posted by raytrix
Need to dump that another 1.5", looks goofy right now and you probably need to add more negative chamber to that.
Any lower, and he'll be shoveling up snow in the Chicago streets. (you know better than that Ray) I dont even want to go into the whole pot hole thing..
Old Jan 24, 2010 | 10:51 AM
  #1443
GGevoXftmfw's Avatar
Looks good, what all was needed to make your 10.5's fit? How bad was the rubbing on the rotas. Do you think if you had 265s over 275s, would be able to drop it more with no fender mods? I was gonna try to do the 9.5's with the 15 offset and either reuse my 245s or get 265s on tanabe df's or h&r sports. Thanks for the insight bud!
Don
Old Jan 24, 2010 | 11:06 AM
  #1444
Evolution IVGSR's Avatar
Don
The 10.5's with a 265 tire should fit will little to no fender work My friend has my old 10.5's with 275's on his Evo X and has minimal rubbing at full lock of the steering wheel.
Old Jan 24, 2010 | 11:08 AM
  #1445
cpunlamd's Avatar
Evo X: 10.5 > 9.5
Evo 8/9: 10.5 < 9.5
Old Jan 24, 2010 | 11:19 AM
  #1446
Originally Posted by cpunlamd
Evo X: 10.5 > 9.5
Evo 8/9: 10.5 < 9.5
Yes on Stock body I agree 100% to that Evo 8 and 9's look best with a good 15-22 offset and 9.5 wide wheels. Bigger than that with them unless they are wide body looks a little too much. Evo 10's tho pull off 10 or 10.5 wide wheel great They need to be 12-22 offset tho for the Evo 10's to have that nice aggressive look
Old Jan 24, 2010 | 11:46 AM
  #1447
on what suspension setup? thanks
Old Jan 24, 2010 | 01:01 PM
  #1448
aftershock141's Avatar
Function over form. No need to slam it and ruin the handling of this car just for the looks. Maybe if I get a coilover setup later down the road I'll drop it a tad more.
My car will getting aligned this spring with -3* up front and -2* in the rear. Right now it's all out of whack since I just fliped the camber bolts.
If you were going for function over form you wouldn't have gotten a wheel with such a low offset; you would have stayed as close to stock as possible to keep it centered.
Old Jan 24, 2010 | 01:22 PM
  #1449
LRM1981's Avatar
I shaved 2 seconds off my lap time at our local track with a 18x10 +20 wheel last summer, after swapping from the stock wheels and tires. I don't think it had to do with the different tires since the Advans are probably a better track tire than the Nitto Invo's .
Just look Ryan Gates, he's running a 18x10.5 wheel with a low offset. But yeah, he does have an insane suspension setup as well.
Old Jan 24, 2010 | 03:13 PM
  #1450
Could also be due to more experience.
Old Jan 24, 2010 | 03:23 PM
  #1451
raytrix's Avatar
My suggestion about lowering as only applying for spring, summer, fall conditions. In winter, he definitely need to raise it to the max of course. Pot holes, avoiding them should be fine. The minimum height requirement to clear chicago speed bumps is fist height 3".
Old Jan 24, 2010 | 04:52 PM
  #1452
Lowering springs and sway bars is all I know. Not sure what brands he has. He is planing on getting some coilovers this spring tho
Old Jan 24, 2010 | 06:32 PM
  #1453
LRM1981's Avatar
Don
with a 10 or 10.5" wheel with an aggressive offset you'll need to roll the rear fenders, even with a smaller 265 tire. The only rubbing I have is on the front fender liner, It's not a big deal though, I plan on using a heat gun and a hammer to push the liner back a bit. Right now I have -1.4* of camber in the rear with a full roll on the fenders and it just barely clears.
Old Jan 25, 2010 | 09:56 AM
  #1454
OakosAutomotive's Avatar
Dang!! That Gunmetal looks fantastic!!
Bart
OAKOS Automotive
  #1455
Whoops!! Double post.
