BlackTop CF V-Style Lip on PB
#31
It was 50% the hangers fault.
The first time installing it, I just removed the aero lip (didn't remove bumper), and kept the hanger on. The CF lip installed fine, but didn't fit properly, no matter what I did.
The second time, I took the hanger off, attempted to install the CF lip without the hanger, but there just isn't enough support without the hanger. I'd say the hanger is required.
Here's the thing though, the two metal clips on the CF lip have big holes on them, so there pretty much wasn't any way to get it to fit properly, and even if I pushed it in, and it looked fine, it slid out of place a bit after driving over a couple of bumps.
I fixed this by removing two clips from the hanger and then I attached them to the clips on the CF lip. I then used a screw to keep that clip in place (so it wouldn't slide), making a total of 2 screws in each clip. (If anyone is having trouble installing this lip, and would like details on how I fixed the fitment problems, I'm more than glad to take photos and type up some detailed instructions).
But anyway, then I installed the lip to the hanger, and it fits PERFECTLY and it feels very sturdy and tight.
I didn't drill the one hole on each corner, but the two bolts in the middle and the tight-wrapped fit are sufficient enough to keep the lip on without any side support.
Overall, the lip fits great and looks great for the price. Could have used two more holes/clips for the middle, just for peace-of-mind, but it's good enough, and I don't regret this purchase.
#32
i just installed mine today.and im having problem to fit it right on the front where the fog lights are.still showing the color of my bumper which is red by a couple of mm on both side.whats the solution on this one?i removed the hanger but still it doesnt cover the whole bumper where the fog light are.so i put back the hanger instead to make it sturdy.any advice? and the double m tape it doesnt stick on the side, is the double m tape to thin to stick on the side?does anybody have problem like this?need advice...thanks
#34
what ravspec said about the weather on the double sided tape but mine stuck and it was about 40 outside when i did this.
