Tall wing install on my non-SSS GSR!
Old Feb 6, 2014 | 11:02 PM
  #31
MysticKnight's Avatar
this wing is much better
Old Feb 7, 2014 | 08:56 AM
  #32
butters149's Avatar
Originally Posted by zebra4
I have personally installed 3 tall wings on non SSS X's. I have only ever had to drill 2 holes, 1 per side. The holes are already "marked" being that you can see the indentation where the holes should be. Also, i would recommend to anyone doing this, to grab some sealing tape and lay it under the spoiler before you bolt it down. Once you drill new holes, they would let moisture into the trunk.
when you say sealing tape you mean like 3M double sided tape? SHould I put it around the holes of the bolt or around the whole base of the wing? Also did you have to buy any hardware or gaskets from Mitsubishi?
Are there indents for two holes per side or just one?
Old Feb 9, 2014 | 10:27 PM
  #33
Lockfinn's Avatar
Veteran: Air Force
Much better.
Old Feb 11, 2014 | 10:02 AM
  #34
zebra4's Avatar
I used some 3M double sided tape, it works great. I put it around the edges of the base on both sides. I purchased nothing from Mitsu. I had the correct fitting hardware in my garage.
There is only 1 indentation per side, as only 1 hole needs to be drilled per side.
Old Feb 14, 2014 | 02:25 PM
  #35
evo2k21's Avatar
way better looking imo
L888Apex
Dec 13, 2009 02:17 AM
chargespeedMR
Nov 24, 2009 07:07 PM
hkopenep074714
Oct 8, 2009 04:19 AM
