Good looking engine bays - EVO X style!
Old Dec 28, 2009 | 04:42 PM
  #136
AWDTerror's Avatar
Old Dec 28, 2009 | 06:48 PM
  #137
Olaboy808's Avatar
Originally Posted by iEvoX
ETS Intake and UICP powdercoated white! Great products!
Absolutely dig the white PC'd pipes!
Old Dec 28, 2009 | 07:35 PM
  #138
AP2_SUZUKA's Avatar
these are some nice engine bays...
Old Jan 2, 2010 | 02:05 PM
  #139
1sicknickel's Avatar
Here is my engine bay as of today Im adding a few more things to clean it up a bit.
Old Jan 11, 2010 | 01:20 PM
  #140
Fishstix's Avatar
So far
It will be complete next month. More Colt Speed and ARC, and the Samco radiator hose in white.
Old Jan 11, 2010 | 02:08 PM
  #141
prack7's Avatar
^ I love that engine cover
Old Jan 11, 2010 | 02:15 PM
  #142
migs647's Avatar
I have a slightly O/T question...
What is the point of the engine cover? Is it just for looks or does it actually serve a purpose?
Old Jan 11, 2010 | 03:25 PM
  #143
Fishstix's Avatar
That particular one is supposed to dissipate heat, but I got it for looks. I think it looks a lot more complete than a valve cover.
Old Jan 11, 2010 | 03:52 PM
  #144
migs647's Avatar
Reason i asked is because the JDM ralliart cover is a lot smaller than all these other ones. I figured it would be able to release more heat without a cover being over the engine.
Here's a shot of my engine bay... nothing much...
Old Jan 16, 2010 | 01:49 PM
  #145
cpunlamd's Avatar
The MIVEC wire to the exhaust sensor in the rear will need to be cut and extended in order to tuck it correctly.
Will cutting the MIVEC wire and extending it mess with the voltage running through the wire? I know for the o2 sensors, it would ruin it.
Anyone know???
Old Jan 17, 2010 | 02:12 PM
  #146
pstl_pete's Avatar
Here's mine.
Old Jan 17, 2010 | 03:06 PM
  #147
bluegsr's Avatar
sexy ^^^
Old Jan 17, 2010 | 03:13 PM
  #148
Blue_CobaltSS's Avatar
Anyone know???
can I bump this too
Old Jan 17, 2010 | 03:29 PM
  #149
Evo a Mula's Avatar
thATbcolt speed engin cover is nice... what do people use to clean their engin bays
Old Jan 19, 2010 | 11:16 AM
  #150
Frankiago's Avatar
Anyone know???
Cut it, extend it, you'll be fine.
Just make sure your connections are electrically sound, maybe include heat shrink tubing on both sides and before you seal the heat shrink tubing on either side, use a multimeter on resistance (ohm) setting (pull negative terminal on battery first! never measure resistance on a live source!). Measure from the exposed OEM wire side to the other exposed OEM wire side. If it reads 0.1 ohms, you'll be absolutely fine. If it reads more than 0.1 ohms, your connection sucks, rinse and repeat.
PS: if you use that same meter and measure the ends of a cut of bare wire and get more than 0.1 ohms, your multimeter's leads are corroded or has frayed wire or something's wrong...
