Is this clearcoat peel??
Old Jul 25, 2010 | 08:57 AM
Mag00n's Avatar
Just noticed this on my driver side door...it looks like clearcoat peel or maybe wax peel?
If you run your finger over the edges you can feel a slight raise.
Old Jul 25, 2010 | 09:04 AM
ct78155's Avatar
Yes, that's commonly known as "orange peel" in the clear coat.
That can be sanded and buffed out, I would take it to a body shop or someplace where they do detailing.
Old Jul 25, 2010 | 09:06 AM
Drew_FL's Avatar
To me, ive seen that on my car and i thought they were just scratches from my key or something.
Old Jul 25, 2010 | 02:33 PM
JEP's Avatar
JEP
Dont even try to wet sand a evo x! The clear is thin you'll go through it with 3000grt in about 3 seconds...
Old Jul 25, 2010 | 02:37 PM
Svendiesel's Avatar
I dont think he is asking about the orange peel, seems like he is pointing out the white lines in the photo.
Old Jul 25, 2010 | 05:06 PM
BrendanS's Avatar
You're either talking about "orange peel" where the finish on the paint resembles the bumps on the skin of an orange. Or the scratches in the clearcoat. Either way those scratches look deep enough that they would need to be wetsanded out and the only way to remove orange peel is by wetsanding the entire car. I wouldn't worry about orange peel as it's common on pretty much every car you see.
Old Jul 25, 2010 | 05:26 PM
SOG RA's Avatar
Depending on where it is on the car, looks like maybe right near side skirts, it could just be something that flung off your tire. I get this sometime with road tar.
Old Jul 25, 2010 | 05:57 PM
heavyD's Avatar
The scratches look like they aren't past the clear coat. You could probably buff it out with a mild polish but be careful as someone has said as it won't take much to burn through to the paint. Japanese water based paint FTL.
Old Jul 25, 2010 | 07:09 PM
tephra's Avatar
the rippled paint = ORANGE PEEL
the white mark looks like a key OR dryed soap markings.
wash it, clay it, buff it out..
dont worry about the orange peel
Old Jul 26, 2010 | 07:08 AM
Spy007's Avatar
Yeah, its orange peel as others have said...
I would just use some good polishes on it to buff out the peel if it really bothers you. The factory paint job seems to be really crappy.
Old Jul 26, 2010 | 08:28 AM
HybridKOOP's Avatar
No polish or compounding will take out orange peel without ruining the paint job.
You'd need to level the peel with wetsanding, then compound, then polish, then wax/seal. I wouldn't do this on an EVO because of thin paint.
However, many Corvette owners (a lot of ZO6 guys) will have this done professionally since GM tends to lay the paint on a lot thicker.
Lou
Old Jul 26, 2010 | 09:22 AM
Spy007's Avatar
Lou
Wetsanding a clearcoat this thin is worse than doing a bit of multi stage compound polish. No way is the factory coat going to ever be smooth enough to look like glass, so just compound polish out a bit of the orange or get the cars paint redone.
Old Aug 1, 2010 | 06:19 AM
bboyhustlerx's Avatar
i have had the same "lines" on previous japanese cars (all black) they are usually spider webbing which has dried in the sunlight on the car or you have driven over some chewing gum on the road - get it off asap its a C*** to get out when its been there for a while.
The paint has definately got "orange peel" you wont really be able to do anything about it unless you can use a very light grade pad and orbital polisher. anything done by hand will only make it worse.
the reason for this is polishing by hand doesnt create enough heat/friction on the surface of the paint to clear off any of the impurities which come from soap/cleaning your car.
bwracing00
45
Nov 18, 2010 08:26 PM
DrivelineSales
Sep 29, 2009 02:18 PM
Wick3d3vo9
Jun 22, 2009 06:43 PM
93HardTopTurbo
Jul 31, 2008 02:14 PM
93HardTopTurbo
Jun 25, 2008 09:17 PM
