Quad projector headlights in the making
Old Mar 30, 2013 | 11:36 PM
  #211
el3ment's Avatar
Love your work dude.. seriously.
Especially those http://i527.photobucket.com/albums/c...I/DSC03243.jpg
May I ask if you still make them and if so, how much would it cost to get them done?
Old Mar 31, 2013 | 12:26 AM
  #212
PonoPride's Avatar
Subbed for info as well.
Old Apr 1, 2013 | 07:32 AM
  #213
Jay10Ralliart's Avatar
FCOTM Winner
I am also seriously interested in doing something like this too.
Old Apr 2, 2013 | 02:07 PM
  #214
Chaz17's Avatar
Sub'd.
Old Apr 3, 2013 | 02:43 AM
  #215
iEvoVII's Avatar
I have a few other sets of headlights that I need to update my thread with...
Stay tuned!!
Old Apr 3, 2013 | 07:04 AM
  #216
el3ment's Avatar
I've pmed you
Old Apr 14, 2013 | 12:36 PM
  #217
evo2g0's Avatar
I have a few questions concerning the Red LED that you installed inside the projector.
First of all, from what I can see, you dremelled a hole at the opposite side where the red shield is. Is it not interfering (in the way) with the light coming out of the HID bulb? Is the LED bulb sticking out inside the projector?
Do you have pictures of the positioning of the hole from inside the projector?
Second question, is there a chance that the LED bulb melts from the heat coming out of the HID bulb? I believe the projector itself can become pretty warm.
Last question, which type of LED would you recommend and can you advise where I should be getting it?
Awesome work by the way, you are very creative
Old Apr 15, 2013 | 07:46 AM
  #218
iEvoVII's Avatar
^^ this was the final retrofit of the LEDs. They are suspended above the projector hole using a metal wire coat hanger that was cut & bent to shape usbg trial & error. It screws into the back of the projector. The reason for mounting the LED this way was so the owner could unscrew the bracket and remove the the LED from the back of the HL incase it ever died. No need to reopen the HL.
It was a good idea in theory but quite tricky in practise. There's very little room to wriggle the LED out. To make things worse you're working blind coz the bracket curves I've the projector. I tested the removal and install of the LED which took a few goes but for someone who hasn't seen the internals of the HL and doesn't know what clearances he/she has then its difficult..
To answer some of your other qns:
* Hole location was dependant on some of the HL internal obstacles. Also depends what projector you use. EvoX-R or Mini H1 projectors don't require holes as theyre an "open" style projector.
* LED interference was not an issue coz it was fixed above the hole
* LED positioning was fine with any heat related issues
* I had to use the most compact LED I could find coz there very little room to work with. I ended up going with this style LED:
Short LEDs
Old Apr 15, 2013 | 11:55 PM
  #219
el3ment's Avatar
This may be a silly question, but couldn't you silicone the LED in? That way the whole is sealed (not that it matters) but you woulnd't have to use that bracket.... just a thought.
Old Apr 16, 2013 | 12:32 AM
  #220
iEvoVII's Avatar
The bracket is used so that anyone can still remove LED from the back of the HL incase it fails. You don't need to re-open it to get access to the LED.
If all you used was silicone to hold it in how would you change LEDs without re-opening the HL??
Old Apr 21, 2013 | 08:44 AM
  #221
evo2g0's Avatar
One more question, concerning the red shields this time. I've just created 4 shields, but as far as I know, the shields I made for my 2 bi-xenon FX-R projectors will be in the way when I turn my high beams on...
In the pictures you posted, which were for bi-xenon projectors, your shields are going almost all the way to the middle of the projector lens. Have you not lost the high beams by doing so?
Please explain!
Thanks
Old Apr 21, 2013 | 06:47 PM
  #222
iEvoVII's Avatar
^^ drop the cutoff shield with your finger then adjust the aluminium shield accordingly
Old May 27, 2014 | 05:57 AM
  #223
FloopyDisk's Avatar
Any new updates?
Old May 31, 2015 | 06:54 AM
  #224
ThatLancerKid's Avatar
Originally Posted by iEvoVII
This is my last one i did for a friend:
https://www.evolutionm.net/forums/ev...eadlights.html
These are the parts needed for the next one:
1.
2.
3.
2 sets required
4.
2 sets required
5.
4 required
6.
4 required
Stay tuned!!!!
For the CCFL have a 80mm think and a 90mm think. That one do you use for the innner side
Old May 31, 2015 | 10:22 AM
  #225
Haven't finished the project bro! Painting is the LAST step. Have to make sure everything fits / bolts up first..
Side note:
If anyone is interested, I can make a DIY thread to achieve the same or similar look as these HLs. The thread will contain:
* ALOT more detailed pix outlining crucial dremeling dimensions for everything. Even behind the scenes pix.
* instalation pix for everything
* create and send dremel templates. Takes most of the guess work out of trimming.
* recommendations on where to buy retrofitting parts.
* + any other information that I think may help
I guess it all depends on how strong the desire is to want to:
* Upgrade the OEM projector
* Achieve a "quad projector" look and lose the operation of the DRL.
Did you make it?
