Quad projector headlights in the making
yeah these are running E46-R shrouds... OEM's E46's are more expensive and not that easy to find.... Yous look better..
The E46-R's in the low / high beam housing are 3". Have to cut away more of the OEM housing... The 2.5" OEMs in your low / high beam are a better size for that housing...
+ you get White XENON logos
Its been a while since I've posted here.. I might as well give an update on the last 2 sets that I've finished:
This set is exactly the same as MonsterP's "White Demon" set:
Specs:
* FX-R BiXenon projector replaces OEM Hella BiXenon unit
* 2.5" OEM E46 shroud with "XENON" retrofitted in low/high beam housing
* Front half of OEM projector retrofitted into DRL housing for the "Quar Projector" look only (non operational)
* 3" OEM E46 shroud with "XENON" logo retrofitted into DRL housing
* Custom aluminium shields painted red and installed inside projectors to give the red look when headlights are off
* Red LEDs custom mounted in all 4 projectors to give the red glow at night
* Quad CCFL halos with a light coat of black paint to give a more stealthy look when not activated
^^ are going in a regular lancer. Just waiting to receive install pix from owner
This is the latest set I've completed:
Specs:
* FX-R BiXenon projectors replacing OEM unit
* 3" E46-R shrouds (No XENON logo's) retrofitted in low/high beam & DRL housings.
* Front half of OEM projector in DRL housing
* Custom white shields to make projectors appear white
* Quad CCFL halos with light coat of black paint for stealthier look
* NO LEDs install for this set
Specs:
Specs:
