I have been looking around and I cann't find a plug and play kit for my gsr. If anyone knows a place that sells a kit that bolts right in without drilling please post a link.
Thanks,
Alex
Thanks,
Alex
any kit will fit, you just need to get the correct bulb, h11 i think it is. also if you want a plug and play you will probably need to get a harness that goes from 9006 to h11, you can try to google ddm they sell affordable hid kits
Quote:
Can you post a link for an example?Originally Posted by JoeyM3
Thanks
Thanks!
I believe the evo x is a h11 but do i need any of the other stuff?
HID harness?
error eliminator?
Adaptor Cable?
HID harness?
error eliminator?
Adaptor Cable?
you'll just need the kit and the adapter that goes from 9006 to h11 if you want true plug and play. you will probably have to google and find the adapter, i don't think ddm carries that.
If the stock foglight is H11, why do you still need a 9006 to H11 adaptor? In short, if I buy a H11 HID kit, do I still need that adaptor?
Nope I have HID foglights its plug and play all you have to do is get a H11 hid kit. then its simple as swapping the bulbs out the tricky part of it is where to put the ballast.
Quote:
I double-sided taped/zip tied mine to the 'shelf' above the fog light. Once you have the bumper off this is a 10 minute install.Originally Posted by josecruz
This is where I got mine. If you live near SD or OC (California), you can just go there and they will help you out. Plus their LIFETIME WARRANTY on the bulbs helps out a lot !!
I just picked up a gsr evo x it's not a sss so I'm trying to get hids now. Is it the same bulb for the fogs as it is for the regular lights? I'm most Likly going to be redeeming from ddm but I don't know if I need any of the extra parts like the harness and adapter cable. Someone please help
