Radium Engineering Surge Tank
I got an Evolution X with 550 Whp and 379 Torque also have the updated Fuel pump relay. At times I still go lean at times and I was checking some things out and was curious about Radium Engineering Surge Tank ? And how they could improve and make it either more rich or just have a better overall volume of fuel. So my question is then is this surge tank really worth the 1k or so to add it to have a better fuel flow of is the DW 550 pump and relay update good enough?
surge tank is amazing when installed right
need more info on your set up to help you out more as to why you are going lean to tell you if a surge tank is right for you. and what type of fuel are you running and what are feature goals for the car hp wise and driving wise
A good option for you would be to also add on the easy performance fuel pump controller. This would allow you to custom tune fuel pump voltage based off boost pressure.
Anyway, surge tank is mostly there to prevent fuel starvation. But, it will allow you to easily run whatever pumps fit and not worry about the oem fpr relay anymore.
krisiun
18
Nov 23, 2013 10:13 PM
Hiboost
Apr 12, 2012 05:53 PM
SlowCar
Jul 14, 2007 07:57 PM
