Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Ohlins R/T question
Old Apr 21, 2016, 06:13 AM
EVL4B11MR's Avatar
Ohlins R/T question
Sup guys just had a question, need more info if possible.
Going to be buying some Ohlins R/T's for my 2014 Evo MR here soon from MAP and was going to pick up the Vorshlag Mitsubishi Evo X Camber/Caster Plates & Perches. What im trying to find out is, does anyone know the spring perch size on the R/T's? I need to run the Vorshlag Perches so i need to either order the 2.5's 2.25's or 60mm spring perches..
Thanks for your time and hope to hear from you soon
Brian
Old Apr 24, 2016, 08:08 PM
Robevo RS's Avatar
for street drive and light rack use the stock top mounts are absolutely perfect. And quiet most quiet ones + never looses the position either.
But that is just my opinion. Spring rates , you better off if you talk and ask Ohlins service about that.
EVL4B11MR (Apr 28, 2016)
Old Apr 28, 2016, 07:46 PM
Keng_v's Avatar
I've herd nothing but great reviews about Ohlins. I will be saving money for this setup.
Old Apr 28, 2016, 07:53 PM
Keng_v's Avatar
Old Apr 28, 2016, 07:59 PM
EVL4B11MR's Avatar
Yea MAP has them in stock and ill be placing the order next week for sure, just too bad they dont have the whitelines control arms in stock or id order them as well.
Old May 10, 2016, 12:47 PM
Esthetics's Avatar
I've been running Ohlins since 2011, haven't had any problems with them and the ride is very good for a coilover setup. You're making a good choice with these. My spring rates are: Front 515 lbs/in; Rear 572 lbs/in if that helps you out at all.
Old Aug 2, 2016, 04:50 PM
DCX
DCX's Avatar
EVL, i was just wondering which option you had selected for the strut style?
There is an R&T on the list i can see, but when i spoke to vorshlag, they mentioned there as DFV too?
Both very similar but have slighly different lengths?
These are the ohlins i have
https://www.maperformance.com/produc...ion-x-mis-mi10
Also, spring ID should 65mm or 2.5" from factory as confirmed by Vorshlag
Old Sep 1, 2016, 08:08 AM
moladin's Avatar
Brian
Sorry, if this is a stupid question, but why can't you use Ohlins R/T Camber plate? It comes with one already. I measured it with caliper, and it is indeed 65mm.
Old Sep 1, 2016, 08:25 AM
nemsin's Avatar
You should just consider getting a set of MCS 1 way, with vorshlag camber plates and hyperco springs http://www.vorshlag.com/shocks.php
Give Vorshlag a call and tell them your goals and see what they suggest.
P.S. By the time you get Ohlins R&T, swap out the camber plates, and add custom springs you will have spent MCS 1 way type money anyways. Imo, MCS > R&T, even on the street (yes the damping is that good).
Old Oct 26, 2016, 06:05 PM
SW2 Tuning's Avatar
Ohlins are always fantastic in my experience.
Grimgrak
Nov 18, 2012 09:20 AM
EVO316
May 25, 2008 08:50 PM
Luffy
44
Jan 16, 2007 01:28 AM
Luffy
37
Oct 16, 2006 06:30 PM
.MM
Jun 13, 2006 10:34 PM
Quick Reply: Ohlins R/T question
