staggered fitment on an EVO?
Can someone answer my question?
Is staggered fitment ok on our Evo's? I assumed that all wheel drive cars cant do staggered? Ive seen people do it
IS there a downside going staggered ?
18x9.5F and 18x10.5R Same tire size all around though.
https://www.evolutionm.net/forums/sh...d.php?t=346682
ok well since this is my first all wheel drive car lets do some critical thinking you and me. well when I had a rear wheel drive car(RX8) I put wider wheels in the rear for more traction. ok that makes sense to me since the power is sent to the rear and i want a larger contact patch. so since the evo has all wheel drive it will seem to me that if you stagger the wheels you will be lowering the cars ability to perform. since we do have an all wheel drive set up the ALL the wheels get power so I would think that all the wheels need the same contact patch. But what the hell do i know im just taking a wild guess. If your into looks more then performance then go for it im guessing. hope that helped -------Captin X and the Xsticals
only down side of this I see is it will get expensive on rotating tires cause your gonna have to have the unmounted and remounted and my guess is just for show
... I would just run widest rim front and back same offest so I could rotate with ease oh and do it myself.
STevo
... I would just run widest rim front and back same offest so I could rotate with ease oh and do it myself.STevo
Heres my set up that I was thinking..
20x8.5 +25offset
20x9.5 +15 offset or +25 offset
Tires: not sure yet...(what do you guys think?)
or I can go 20x8.5 +25 offset all around with a 255-30-20
or
19x8.5 +20 offset
19x9.5 +20 offset
Tires: 245-35-19
20x8.5 +25offset
or
19x8.5 +20 offset
19x9.5 +20 offset
Tires: 245-35-19
thats not JDM, thats a U.S. thing. we do that to compensate for stiff rear sway bars, to keep the rear end in check -as we run more oversteer setup, while the JDM guys run more of an understeer setup.
If i were you, i wouldn't bother staggering them. there's no point.
I wouldn't run the staggered fitment as theres no real benefit. Plus you aren't going to be able to properly rotate your tires. If you do run the same size tireall around and a staggered fitment the rears are going to have the stretched look. Just my .02's
Racecarzz08
May 8, 2009 09:09 AM
