BBK options
Bbk
Keep in mind the size of the rotors and the size of your wheels. Some really big rotor kits will require 19" or larger wheels.
Turbo & High Tech Performance (Sep 08) just put out an article about the Brembo GT 355 Kit and they only had .08mm clearance from the inside rim of the front wheel (Brembo recommended .12mm). A little close for comfort I'd say.
Their wheels were the Volk CE28Ns (and they didn't specify the offset) 18x9.5.
BBKs
True enough. Apparently the Brembo GT kit I mentioned sticks up just shy of 2.0in off of the edge of the rotor (355mm~14in).
It would all depend on the caliper, and I don't recall seeing any specs posted out there that state how far the calipers rise off the edge of the rotors. That would be nice, but then again, they never really say how far the calipers stick off the side of the rotors either for your offset check. The brake manufacturers just tell you to do a fit test or use some darn template they post in a PDF file.
Last edited by 59EVO; Jun 11, 2008 at 12:49 PM. Reason: grammar checked the quote for clarity
As street pads suck on the track, and like to catch on fire. And track pads dont like to stop on the street.
With that being said, the 2500's are probably the best cross over pad.
neogeo64
10
Feb 6, 2018 07:42 PM
TeKiZeRo
Jan 10, 2011 09:01 AM
discopotato03
Jun 21, 2010 04:18 PM
