Okuyama CARBING Center Frame Bracing / Lower Arm Bar
Okuyama CARBING just released a ton of intersting parts for the X in Japan:
http://www.jdmtuningnews.com/articles/72508a.htm
Okuyama CARBING has let loose with several new components for Mitsubishi's Lancer Evolution X (CZ4A). Their Front Lower Arm Bar Type I is constructed of steel and carries a Product number of 680 329 0, retail is 12,600 yen including tax. The Driver Footrest carries the Product number 313 329 0 features dimples and is made of aluminum, retail is 5,775 yen. The Under Panel acts as a frontal diffuser and carries a Product number of 509 329 0. It features louvers on the surface of the panel and allows heat in the engine room to be efficiently released. A service area exists under the oil filter for easy access. It is possible to use this product with the Lower Arm. Retail is 31,500 yen. Finally, the Center Frame Brace carries a Product number of 694 329 0. It's made of steel and the installation procedure is bolt on. It retails at 24,150 yen.
BUMP!
Noob questions: does the center frame brace replace a stock brace? If so, how does it compare to the stock one? What does it really do in real world driving (I know it add chassis rigidity but how does that translate into actual driving feel)?
Saw this on sale at a local shop for $210, wondering if I should get it.
Anyone have info on the Carbing center frame brace (whether it replaces a stock piece or is it an add-on? what does it do in real world driving?) I googled and searched the forums but couldn't find much beyond a few people have them in their mod lists.
Anyone? Is it an add on or replacement?
Interesting.
That would seem to be the equivalent of the Cusco front lower brace:
It's using the same two points on the chassis, but different points on the subframe. I have no clue which is a better approach.
Does Okuyama also make a brace that connects forward from the subframe? Cusco does:
In any event, my (limited) experience with bracing subframes is that it is not worth it unless you are running R-compounds or better. But if you have swapped all of your bushings for poly or better, and the car still doesn't seem tight, maybe....
redlinedrift
13
Jul 9, 2008 11:02 AM
