Any reason to NOT go with an 8.5" wheel?
Isn't the stock wheel 8.5"?
I'm just trying to sort out my options. I need to continue to run 245 wide tires for SCCA, so I don't need more metal for more rubber, so why would I go 9", 9.5", or 10"?
Wider wheels will likely be heavier, right?
Thanks!
Thanks!
+1 at 8.5...and wider wheels are not always heavier. I have a set of 9.5's that with rubber weight less then stock....more rubber can never really hurt. Check Ben Graham or Blacktrack-they both run NASA TT and run pretty great set ups.
What type of SCCA racing do you do? I thought you need to run stock width, can't change offset by more than 1/4" that's all in all stock classes for SoloII (autox). But then again 245 is the max. the tire manufacturers recommend for 8.5" rims. But what you can do is look for those 245mm tires that are wider than others - Hoosier A6/R6 are the first that come to mind. The 225 A6 on my Lotus is just as wide as the 245 Kumho V700
I said 8.5" It was someone below me that said 8"
For autocross, in the STU class, AWD vehicles can run a max of 245 wide tires. And the Dunlop Star Specs basically rule the roost for AutoX tires.
Well the Kumho 245/40 ZR18 tires have a Rim Width Range of 8.0"- 9.5" but the measured rim width is 8.5" where the tire isn't being forced to go narrower or wider than it's natural mold on a wheel. Usually going slightly narrower on the wheel size will make the sidewall less rigid where as slightly wider would make it more rigid, but 9.5" might make it look like they are barely fitting the wheels and stretch the sidewalls inward a bit too much.
This may depend on the brand since the section width is 9.9" on that particular tire. I know that the wheel widths are measured inside edge to inside edge where the tire is seated, so the outer edge to outer edge on a 9.5" wheel would be 10.5" and be wider than the section width. This is assuming the lip is .5" on each side which seems to be what I've seen on most wheels I measured.
Hope that helps.
Hope that helps.
Evolution8.5
42
Oct 23, 2017 05:42 PM
fthamma
10
Mar 8, 2012 08:52 AM
evox7
13
Dec 1, 2007 12:12 PM
BPAuto
Feb 11, 2004 03:55 PM
