Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
lug nut torque?
Old Jun 23, 2011 | 06:02 AM
deanob's Avatar
IMHO 75/80 is too low. 90~ is perfect.
Old Aug 27, 2012 | 02:07 PM
orig6redwings's Avatar
Ran across this thread and had to comment. DO NOT use anti-seize or any type of lubricant on wheel lug nuts. As it was posted earlier, manufactures calculate torque for lug nuts using a dry torque. So, you should NEVER use any type of lubricant when installing and torquing lug nuts. Using a lube can over torque the wheel and that can possibly warp your expensive rotors.
Old Aug 29, 2012 | 10:51 AM
ProjectGSX's Avatar
The previous poster said 75 with anti-sieze. 90 would be dry.
Old Jan 27, 2013 | 07:18 PM
EvoNoob00's Avatar
FLM I'm coufused!
yes use anti-sieze or no
and what about water proof grease to keep moister out?
thanks!
Old Jan 27, 2013 | 09:45 PM
punn303's Avatar
I've always torqued at 85 dry with several wheel changes and never had an issue.
Old Jan 28, 2013 | 06:23 AM
Originally Posted by EvoNoob00
FLM I'm coufused!
thanks!
According to numerous websites. The correct lug nut torque is 80 ft-lbs. Here's a couple of websites in particular:
http://www.torkspec.com/torkspecmm.aspx?KI=385
http://www.ktoolinternational.com/PD...utorqchart.pdf
As I stated above, you should never use anti-seize or any sort of lubricant on your lug nuts/studs. When engineers calculate the lug nut torque, they do so without the use of a lubricant (or dry torque as previously stated). As long as the lug nuts are installed and torqued correctly, you should never have an issue removing them using the manufacture's specified torque. 80 ft-lbs isn't a lot of torque. Also, if you have alloy/aluminum wheels, make sure to drive the vehicle about 250 miles and re-torque the lug nuts.
Using a lubricant can possibly result in a few different issues. One is over-torquing the wheel. While the other can be under torquing the wheel. A lot of that also depends on how often your torque wrench has been calibrated. Using a lubricant on the lug nuts can/will provide a false reading, to the torque wrench, from what the the manufacture intended. This is straight from one of the major US manufacture's service manuals that I write:
NOTE: Never use oil or grease on studs or wheel mounting (lug) nuts.
I understand that a few people on here have used anti-seize or a lubricant on their lug nuts, but in my 22+ years in the auto repair business, I have never used any type of lubrication on lug nuts and I have never had any issues. So, to each their own.
I am an ASE certified technician of 22+ years and I am currently a Service Engineer who has (and still does) created the mechanical and electrical service information (Service Manuals) for numerous American and Foreign auto makers for 12+ years.
I hope this helps.
Old Jan 28, 2013 | 06:52 AM
Kracka's Avatar
I always do mine to 75 ft/lbs.
Factory spec is: 73 ± 7 ft-lb
Old Jan 28, 2013 | 09:29 AM
Jason S-9's Avatar
I use anti-seize on mine but just because I have open ended Kics lugs, a friend of mine had one of his lugs break off cause the corrosion build up inside (lugs are steel btw). I torque to 73ft-lb with anti-seize, 80 without.
BTW what a F-in mess trying to get that broken lug out without damaging a VOLK CE28
Old Aug 27, 2013 | 08:26 PM
noctrnlgunfitr's Avatar
You should never use anti seize on lug nuts. Should always go on dry. As far as compensating for a 10% out torque that is crazy. If you suspect your torque wrench is out get it re-calibrated or buy a new one. Never use a torque wrench to remove anything that will screw them up every time. Always use your service manual for torque values there is alot of engineering that goes into proper torque. Dont rely on a general spec for small cars that is also crazy. I have seen torque on nissans at 65ft/lbs and hondas at 82ft/lbs and chevy cavaliers at 100 ft/lbs. Lug nut torque should be done by hand always with a good torque wrench. Don't use torque sticks either they slowly wear out and put less torque then spec. You dont want your wheels coming loose killing you, your family or some else. I know this because i'm a journeyman automotive tech and a 4th year heavy duty mechanic with over 12 years in the trade.
Old Apr 10, 2020 | 12:06 AM
EdBoy_EvoX2015's Avatar
Official specs for lug nut torque
I know this is a super old thread however I never saw someone actually give the actual Manuel answer. So here it is. On page 8-10 of my 2015 Evo X manual it states that 65-80ft-lb is required. However I feel like it's better to be safe than sorry so I would recommend 80ft-lb.
butters149
Mar 7, 2014 12:18 PM
tlr9
19
Mar 7, 2013 06:52 AM
Mr. Evo X
Jan 1, 2013 08:08 PM
ksemski
Jul 24, 2012 03:27 PM
Xtremist
14
Aug 6, 2010 01:55 PM
