Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
18x10 +35
Old Nov 26, 2008 | 02:18 PM
beetle_orange's Avatar
i am no expert so by all means correct me but imo on a 10" wide rim you might get away with +25 offset without rolling but you might need a littel bit of negative camber
Old Nov 26, 2008 | 02:22 PM
Red Dragon's Avatar
There is no performance differance in a +25 offset and +35 offset. Its only 10mm. 10mm is big but not big enough to make a differance in handling. Its about the tires. And yes you can go too wide but i dont think you will have to worry about that.
If you go with a +35 you can fit a 275 tire with out any modifications on stock suspension. If you go with +25 you can fit a 265 tire without any modification on stock suspesion. A 275 tire on a +25 rim on stock suspesion will hit the rear fenders and you will need to roll the rear fenders. I am only refering to a stock Evo X and a 10' rim. If you plan to change your suspension, you can fit a bigger tire with the right camber setting.
Get the 10' rim if you can affored it.
Old Nov 26, 2008 | 02:32 PM
evolutionXmute's Avatar
you actually answered all my questions, thank you.
guess i'll be picking up these rg2's... i think it's a pretty good deal for $1600.
regardless, i'll still have my rz's so if i'm not happy with the new wheels i'm fairly sure i can sell them and get my money back.
Old Nov 27, 2008 | 01:31 AM
HB Speed's Avatar
i have KW clubsports and RG2 18x10 +25's
needed a GOOD roll on the back and rubs on the spring perch on the front
running a 285/30r18 bfg KD
im getting 5 mm spacers :-p
Old Nov 27, 2008 | 02:11 AM
kimletrim's Avatar
Registered User
I was able to run wide 275 width Direzza Star Spec tires on stock suspension and it only rubbed on the driver's side corner. I believe that if my toe was set correctly from the factory, rolling my rear fender would not have been necessary.
Old Dec 2, 2008 | 12:14 PM
Speed Element's Avatar
Originally Posted by evolutionXmute
what is the lowest offset that can be run without fender work?
18x9.5 +22
You can still run 275s on 18x9.5 wheels.
That .5 inch won't make that much of difference if you are just using them for DD and occasional track event.
Old Dec 31, 2008 | 07:01 AM
HaleRzr's Avatar
I've got works springs installed on my Evo X Mr (dropped 0.9" in the back and 0.5" in the front). If I want 18x10 +25 AME fs01 wheels with 265 tires am I going to have to roll the fenders or adjust camber?
Old Dec 31, 2008 | 07:23 AM
I <3 Spool's Avatar
There is an 'aggressive wheel and offset thread'. What I took away from reading 30+ pages is that 18x10.5 is an aggressive size, with a 275 tyre....offsets varied, but one particular application was +18. This was a car that was street driven and tracked. Fender work was needed.
My thought is, if you want that aggressive stance, you're going to have to roll the fenders.
Old Dec 31, 2008 | 09:57 AM
xdcharlie's Avatar
Originally Posted by Speed Element
18x10 +35 and 18x10 +25 and 18x10 +15 all have the same width.
its the offset that will give you the stance.
You can also run 18x10.5 +12 if you have the guts to do it
Here is an example of our X w/ Rays SE37K in 18x10.5 +12 275/35/18, front fenders rolled, rear fenders shaved.
OMG sell me those s37k's PLEASE! i'm begging you.
Old Dec 31, 2008 | 12:05 PM
JOEY@WORKS's Avatar
We run 18x9 + 22 AME FS-01 with 245 r888's and haven't had any rub issues ( fenders aren't rolled ). with 18x10 +25 w/ 265 tires, you might be close, but I don't think you'll have any rubbing issues. a little camber and rolling the fenders doesn't hurt as back up though
Old Dec 31, 2008 | 01:56 PM
Vivid Racing's Avatar
I have a set of 19x10 wheels front and rear for the EVO X. Flat gunmetal centers with a gloss black lip. Features a 2" lip in the front and a 3.75" lip in the rear. Toyo T1R 265/30/19 Tires on all 4 Wheels. Less than 700miles on the tires. This will be a direct bolt on to your Evo X without modifying it. I can sell for $2150 Shipped. Let me know get back to me anytime.
Old Jan 1, 2009 | 06:24 PM
Roidmonkey's Avatar
thank you for the link.
does anyone know if i would have any rubbing issues with a 18x10+35 wheel?
+35 is to high . ur wheels r going to be suck in to much . get +25 looks more aggressive
xerxess
Nov 29, 2016 05:56 PM
dsmdion
For Sale - Wheels / Tires
Mar 29, 2016 09:05 AM
Immaculate
18
Sep 14, 2011 06:08 AM
feije29948
Apr 2, 2009 07:30 PM
sikrsix
11
May 6, 2007 02:51 PM
