wheel & Tire size help
Could someone tell me what is best size tire to use on a 18x10 +18 setup lowered on Eibach's. I want to avoid rolling the fenders. Could someone tell me the lowest width I can go and the largest I can go without rubing.
Thanks alot
Thanks alot
At that offset, a lot of what you're going to need to do will come down to camber and the tire (since some tires are wider for the same nominal width).
I think that a 265/35 will be the safest and a skinnier 275/35 will be close. That's a fairly aggessive fitment and I would not be surprised if you rubbed if you don't roll.
You should try and max your camber out front (-2 to -2.5 without camber plates) and maybe go a touch higher than stock (-1.5ish) in the rear.
The stock is 245/40 and the next size up that's almost exactly perfect is 275/35.
So 255/35 will look way shorter than the stock and 265/35 will be a bit shorter.
So now Im looking at 275/35
beetle_orange, how flush are yours to the fenders with the +35? The OP is looking at +18, so that's 12mm closer to the fender.
I think CityTire said that 18x10 +35 fits with no mods to the fender.
i THINK they look perfect. i PERSONALLY feel that if i had gotten a +25 i would have had to roll my fenders, just like what jackygor said. having said that i think they look flush. with the OP going for +18 he is gonna need some major fender rolling and some negative camber i believe. if i can redo it though i would have definitely gone with 275 tires.
if jackygor has a +25 offset and he said he has about half and inch of the tire sticking out i think you may or may not need to roll with a +20 offset. with a 9" width the 245 will be stretched but not as bad as putting 255 on a 10" width tire.
manthny18
May 2, 2017 05:55 AM
mgomez
12
Apr 14, 2017 08:13 AM
autobahntom
For Sale - Wheels / Tires
Aug 11, 2011 03:26 PM
VerbalKilla
Sep 22, 2010 10:50 AM
Rez90
11
Mar 8, 2005 07:05 PM
