Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Stock Wheel and Alignment Specifications
Old Aug 14, 2013 | 12:33 PM
  #76
Kracka's Avatar
Get an alignment and have them zero out your toe. Make sure you are running proper tire pressures. If you're still within 12 months/12k miles Mitsubishi offers warranty coverage on "adjustments" such as a bad factory alignment.
Old Sep 22, 2013 | 09:01 AM
  #77
DRTV's Avatar
What tire pressure do you recommend? I am having the same problem, my inner treads are cupped on all 4 wheels. Had car aligned by my usual shop with 250 miles on the X, rotated 2 times, am now at 7500 miles and car sounds like freight train and the wear is really noticeable. Outer tread wear is minimal, too bad stock tires can't be flipped on the rims.
Running stock toe in front (14 total), total of 19 in the rear, is that the real issue?
Front camber = -1.0
Rear camber = -1.0
My '08 STI had similar wear issues on the inside tread and I was able to flip the star specs when necessary.
Don't want to burn up another set of tires, I DD my '12X and no suspension mods are planned.
Thanks for any advice.
Old Sep 23, 2013 | 08:50 PM
  #78
Canadian Evo's Avatar
I dont have any real good advice, i am currently trying to get my tires covered under warranty. I met with the western canadian yokohama tire rep,he told me the yokohama advan a13 which is the factory tire on most 2013 evos is the firrst year the tire is in production,he figures that is a manufactor defect and they are covered under warranty,but the will only warranty them once the tire is complety worn out,so my best advise is see if your tire manufacturer will warranty ur tires and if not use another tire. I am positive it is not an alignment issue because most inner wall wear comes from negative camber, but almost every sports car runs around -1 camber and doesnt incounter these issues.
Old Oct 2, 2013 | 02:31 PM
  #79
AIM WO4's Avatar
Wheel Comparison
I like this site:
http://www.rimsntires.com/specs.jsp
Old Nov 19, 2013 | 03:05 PM
  #80
flipflop's Avatar
I'm having the same issue with my tires, it's getting uneven wear on the front tires. Seems like the alignment is off but I just got it aligned not to long ago! WTH?! I'm not lowered or anything, stock struts and springs. Help!
Old Dec 2, 2013 | 04:03 PM
  #81
Grape Juice's Avatar
Are these specs safe for the 2014 MR? I called in to a reputable wheel alignment shop and they said they only have specs up to 2012 and that Mitsubishi has not released wheel alignment specs for my car.
Can anybody confirm this? Any wheel alignment shops you guys recommend in the SoCal area?
Thanks
Old Apr 10, 2014 | 06:03 PM
  #82
Nagua's Avatar
Nice read. Thanks guys.
Old Nov 29, 2015 | 08:49 PM
  #83
Chris_tA_4's Avatar
Great info
Old Mar 25, 2016 | 08:58 PM
  #84
donny_utah's Avatar
Veteran: Army
Sweet info! Thanks!
Old Jan 27, 2017 | 02:24 PM
  #85
EuRomer's Avatar
Good info!
Old Feb 25, 2019 | 10:58 AM
  #86
Silverback1's Avatar
Thanks
Old Apr 5, 2022 | 11:30 PM
  #87
pumpkinpot's Avatar
Originally Posted by goofygrin
  • When the car is turned on, the front toe tends to drift. Be sure to have the alignment tech start your car before calling it finished. Mine drifts 0.07* out (equally
Sorry to bump an old thread but I'm surprised no one is talking about this point. I can't imagine how an engine turning over can change a car's alignment.
Old Apr 6, 2022 | 08:35 AM
  #88
ViciousLSD's Avatar
in general, you have to roll the car so the suspension/steering/tires will settle in its normal position. power steering running and turning the wheels a bit while tires are on a plate (or sheets of paper for me) helps in my experience
Old Jul 24, 2022 | 08:22 PM
  #89
Trax_'s Avatar
Dope, great info here!
rgonyer
19
Apr 19, 2011 05:55 PM
Deetz
Oct 23, 2009 11:19 PM
nbpal4000
May 26, 2006 06:55 PM
Jasil
Mar 5, 2006 06:47 AM
TexasRS
15
Dec 26, 2004 09:44 PM
