Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Alignment after sway bar install?
Old Apr 29, 2009 | 01:25 PM
simons's Avatar
Do you need to get an alignment after you install a larger rear sway bar? I know you're supposed to after a new front sway bar because you drop the subframe, but I don't know about the rear.
Old Apr 29, 2009 | 02:02 PM
antics22's Avatar
you should be fine with the rear without a new aligment since youre not removing any critical adjustment bolts... its just the sway brackets and the sway links...
Old Apr 29, 2009 | 06:58 PM
XOoET64oOX's Avatar
You should always get an alignment after messing with the rear suspension. But the question I'm still trying to figure out is WHEN. Springs/Coilovers always have that "settling" time frame, and I don't know about other ones. But yea, you should get alignments when things have to be unbolted.
Old Apr 29, 2009 | 07:08 PM
Hiboost's Avatar
Unbolting endlinks and swapping in a stiffer swaybar would have zero impact on the toe or camber settings as far as I know. The whole idea of the swaybar is that it needs to have some play and will center itself where it needs to be.
Old Apr 29, 2009 | 07:14 PM
cfdfireman1's Avatar
^ +1 ^
Old Apr 30, 2009 | 01:17 PM
simons's Avatar
It makes sense you wouldn't need an alignment after a rear sway bar upgrade. You don't mess with a whole lot during the replacement. But a front bar, definitely. Thanks for the info.
iseedipp
18
Jan 20, 2016 11:48 PM
shLa11
Oct 21, 2012 06:28 AM
ericjai113
Jan 16, 2012 11:57 AM
Sickdriver
14
Nov 9, 2010 08:08 AM
ralliartracer
14
Oct 1, 2004 01:47 PM
